[postgis-users] PostGIS+FreeBSD 6.0 (AMD64) and Shared object "libpq.so.5" not found
Jeff Hamann jeff.hamann at forestinformatics.com
Mon Mar 16 14:14:34 PDT 2009
I apologize for the cross post, but I can't seem to get any traction on
solving this problem. I'm a serious autoconf, automake, and libtool
newbie, and I'm trying to get postgis up on a FreeBSD6.0-AMD64, and keep
getting the following results when I gmake test in
postgresql-8.3.5/contrib/postgis directory:
$ gmake test
gmake -C regress test
gmake[1]: Entering directory
`/usr/home/hamannj/postgresql-8.3.5/contrib/postgis/regress'
cpp -P -traditional-cpp sql-mm-circularstring_expected.in | grep -v "^$"
cpp -P -traditional-cpp sql-mm-compoundcurve_expected.in | grep -v "^$"
cpp -P -traditional-cpp sql-mm-curvepoly_expected.in | grep -v "^$" >
cpp -P -traditional-cpp sql-mm-multicurve_expected.in | grep -v "^$" >
cpp -P -traditional-cpp sql-mm-multisurface_expected.in | grep -v "^$" >
Creating spatial db postgis_reg
TMPDIR is /tmp/pgis_reg_86134
 PostgreSQL 8.3.5 on x86_64-unknown-freebsd6.0, compiled by GCC gcc
(GCC) 3.4.4 [FreeBSD] 20050518
 Postgis 1.3.5 - 2009-03-16 20:44:21
   GEOS: 3.0.3-CAPI-1.4.2
   PROJ: Rel. 4.6.1, 21 August 2008
Running tests
 loader/Point....... failed (dumping loaded table:
/tmp/pgis_reg_86134/dumper.err)
 loader/PointM....... failed (dumping loaded table:
 loader/PointZ....... failed (dumping loaded table:
 loader/MultiPoint....... failed (dumping loaded table:
 loader/MultiPointM....... failed (dumping loaded table:
 loader/MultiPointZ....... failed (dumping loaded table:
 loader/Arc....... failed (dumping loaded table:
 loader/ArcM....... failed (dumping loaded table:
 loader/ArcZ..... failed (dumping loaded table:
 loader/Polygon....... failed (dumping loaded table:
 loader/PolygonM....... failed (dumping loaded table:
 loader/PolygonZ....... failed (dumping loaded table:
 regress. ok
 regress_index. ok
 regress_index_nulls. ok
 lwgeom_regress. ok
 regress_lrs. ok
 removepoint. ok
 setpoint. ok
 simplify. ok
 snaptogrid. ok
 affine. ok
 wkt. ok
 measures. ok
 long_xact. ok
 ctors. ok
 sql-mm-serialize. ok
 sql-mm-circularstring. ok
 sql-mm-compoundcurve. ok
 sql-mm-curvepoly. ok
 sql-mm-general. ok
 sql-mm-multicurve. ok
 sql-mm-multisurface. ok
 geojson. ok
 regress_ogc. ok
 regress_bdpoly. ok
 regress_ogc_cover. ok
 regress_proj. ok
 kml. ok
Run tests: 39
Failed: 12
gmake[1]: Leaving directory
$ cat /tmp/pgis_reg_86134/dumper.err
results in the following:
/libexec/ld-elf.so.1: Shared object "libpq.so.5" not found, required by
"pgsql2shp"
Is this because PostgreSQL was compiled using gcc 3.4.4 (old?)? Is this
because there's some switch that's getting set in the makefile
incorrectly. I keep seeing threads from 2005 when I search for, "Shared
object "libpq.so.5" not found" and AMD64, but there doesn't seem to be a
"just include the path that that shared library in your 'path'" solution
and my libpq.so.5 is in /usr/local/pgsql/lib and being a unix sloth, I'm
not sure how to get the OS/Makefile to 'see' the library and I don't
know if this would be taken care of in the ./configure process...
Does anyone have any suggestions?
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090316/c1c1210b/attachment.vcf>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090316/c1c1210b/attachment.pgp>
