[postgis-users] problem with polygons spanning across 180E
sige sigenz at yahoo.co.nz
Mon Mar 16 18:28:16 PDT 2009
Thank you for your response. It seems there is no easy work around, and i
need to store the data as multipolugons and a program is needed to tell
whether a polygon intersects the dateline.
Sige
Paul Ramsey-4 wrote:
> None of the systems mentioned understand geographic coordinates as
> having a "wrap point" at 180. They are treated as planar, naturally
> your polygons connect across the central meridian instead of the
> dateline.
> The only "solution" is to force your data to respect the dateline by
> cutting it in half at 180/-180
View this message in context: http://www.nabble.com/problem-with-polygons-spanning-across-180E-tp22528752p22551034.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
