[postgis-users] Index Use Craziness
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Wed Mar 18 06:04:50 PDT 2009
I am having much trouble getting postgres to use the proper index.
I have a table with about 20 million daily rainfall observation points,
with between 0 and 19,000 points on any given day.  In order to speed up
querying, I have created a GIST index on the geometry column, and an
index on the date column.
What I want to do is to summarize the observed rainfall in another shape
table on any given day.  If I just want to query points by date, this
uses the date index, and performs very quickly (see "CASE 1" below).
When I try to introduce a geometry operator, the GIST index takes over,
and the index on the "thisdate" column is ignored.  The weird thing is,
I can hear it churning the heck out of my hard drive checking on all the
points. (See "CASE 2" below).
I even tried to sub-query the points for the given date, but the index
did not seem to be fooled ("CASE 3").  It gave me the exact same query
plan!!  I am unsure if I really understand the way a sub-query functions
given this result.
Any help would be appreciated!
Robert
CASE 1:
wsp=# explain select count(*) from precip_gridded where thisdate =
'2009-01-12';
                              QUERY PLAN
 Aggregate  (cost=479.43..479.44 rows=1 width=0)
   ->  Index Scan using pg_tdix on precip_gridded  (cost=0.00..451.92
rows=11004
 width=0)
         Index Cond: (thisdate = '2009-01-12 00:00:00'::timestamp
without time zone)
(3 rows)
CASE 2:
'2009-01-12' and the_geom && setsrid((select extent(the_geom) from
proj_seggroups where gid = 448),4326);
                              QUERY PLAN
 Aggregate  (cost=100.23..100.24 rows=1 width=0)
   InitPlan
     ->  Aggregate  (cost=5.87..5.88 rows=1 width=2807)
           ->  Index Scan using psg_giix on proj_seggroups
(cost=0.00..5.87 rows=1 width=2807)
                 Index Cond: (gid = 448)
   ->  Index Scan using pg_gix on precip_gridded  (cost=0.00..94.35
rows=1 width=0)
         Index Cond: (the_geom && setsrid(($0)::geometry, 4326))
         Filter: ((thisdate = '2009-01-12 00:00:00'::timestamp without
time zone) AND (the_geom && setsrid(($0)::geometry, 4326)))
(8 rows)
CASE 3: Sub-query by date to try and force the use of date index
wsp=# explain select count(a.*) from (select * from precip_gridded where
thisdate = '2009-01-12') as a where a.the_geom && setsrid((select
extent(the_geom) from proj_seggroups where gid = 448),4326);
                              QUERY PLAN
 Aggregate  (cost=100.23..100.24 rows=1 width=81)
   InitPlan
rows=1 width=81)
(8 rows)
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
