[postgis-users] Index Use Craziness
Paul Ramsey pramsey at opengeo.org
Thu Mar 19 09:26:49 PDT 2009
Mose,
Thanks for that crystal clear analysis and perfect test case (I just
ran it now, I love test cases I can run with copy-paste). Could you
put an issue in the tracker and reference your mail archive link?
http://postgis.refractions.net/pipermail/postgis-devel/2008-September/003547.html
MCA is the selectivity expert, so I'll leave it to him to describe the
difficulty of figuring join selectivity versus constant selectivity.
P.
2009/3/18 Mose <mose.andre at gmail.com>:
> Robert,
> I have been haunted by similar issues but I haven't had time to figure out
> some explanation I really believe in.
> Does this post with a reproducible case seem similar?  It seems like it to
> me.
> For now when these situations aren't working (the planner favors the spatial
> index due to a weird estimate when it is really going to be lots) I am using
> a constant geometry [e.g. geometryfromwkt(wkt geometry string)] for the join
> condition.  I realize the feasibility of this depends on your application,
> or your desire to write a user-defined function.
> Why does the planner get different estimates for the same geometry being
> used in a constraint based on it coming from a table, or from a string in
> the query?  I think the reason this is happening might be apparent in
> lwgeom_estimate.c, but I'm open to being totally wrong :).
> -Mose
> On Wed, Mar 18, 2009 at 11:32 AM, Paragon Corporation <lr at pcorp.us> wrote:
>> Robert,
>>  Which version of PostgreSQL are you running?  I wander if you are being
>> bitten by one of these bugs
>> --the description doesn't quite match any of these 2 - but it could be
>> another side effect of these
>> http://www.postgresql.org/docs/8.3/static/release-8-3-7.html
>> Fix planner problem with sub-SELECT in the output list of a larger
>> subquery
>> (Tom)
>> Or
>> http://www.postgresql.org/docs/8.3/static/release-8-3-6.html
>> Fix planner misestimation of selectivity when transitive equality is
>> applied
>> to an outer-join clause (Tom)
>> This could result in bad plans for queries like ... from a left join b on
>> a.a1 = b.b1 where a.a1 = 42 ...
>> Hope that helps,
>> Regina
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>> Burgholzer,Robert
>> Sent: Wednesday, March 18, 2009 9:05 AM
>> To: PostGIS Users Discussion
>> Subject: [postgis-users] Index Use Craziness
>> I am having much trouble getting postgres to use the proper index.
>> I have a table with about 20 million daily rainfall observation points,
>> with
>> between 0 and 19,000 points on any given day.  In order to speed up
>> querying, I have created a GIST index on the geometry column, and an index
>> on the date column.
>> What I want to do is to summarize the observed rainfall in another shape
>> table on any given day.  If I just want to query points by date, this uses
>> the date index, and performs very quickly (see "CASE 1" below).
>> When I try to introduce a geometry operator, the GIST index takes over,
>> and
>> the index on the "thisdate" column is ignored.  The weird thing is, I can
>> hear it churning the heck out of my hard drive checking on all the points.
>> (See "CASE 2" below).
>> I even tried to sub-query the points for the given date, but the index did
>> not seem to be fooled ("CASE 3").  It gave me the exact same query plan!!
>>  I
>> am unsure if I really understand the way a sub-query functions given this
>> result.
>> Any help would be appreciated!
>> Robert
>> CASE 1:
>> wsp=# explain select count(*) from precip_gridded where thisdate =
>> '2009-01-12';
>>                              QUERY PLAN
>>  Aggregate  (cost=479.43..479.44 rows=1 width=0)
>>   ->  Index Scan using pg_tdix on precip_gridded  (cost=0.00..451.92
>> rows=11004
>>  width=0)
>>         Index Cond: (thisdate = '2009-01-12 00:00:00'::timestamp without
>> time zone)
>> (3 rows)
>> CASE 2:
>> explain select count(*) from precip_gridded where thisdate = '2009-01-12'
>> and the_geom && setsrid((select extent(the_geom) from proj_seggroups where
>> gid = 448),4326);
>>                              QUERY PLAN
>>  Aggregate  (cost=100.23..100.24 rows=1 width=0)
>>   InitPlan
>>     ->  Aggregate  (cost=5.87..5.88 rows=1 width=2807)
>>           ->  Index Scan using psg_giix on proj_seggroups
>> (cost=0.00..5.87 rows=1 width=2807)
>>                 Index Cond: (gid = 448)
>>   ->  Index Scan using pg_gix on precip_gridded  (cost=0.00..94.35
>> rows=1 width=0)
>>         Index Cond: (the_geom && setsrid(($0)::geometry, 4326))
>>         Filter: ((thisdate = '2009-01-12 00:00:00'::timestamp without time
>> zone) AND (the_geom && setsrid(($0)::geometry, 4326)))
>> (8 rows)
>> CASE 3: Sub-query by date to try and force the use of date index wsp=#
>> explain select count(a.*) from (select * from precip_gridded where
>> thisdate
>> = '2009-01-12') as a where a.the_geom && setsrid((select
>> extent(the_geom) from proj_seggroups where gid = 448),4326);
>>                              QUERY PLAN
>>  Aggregate  (cost=100.23..100.24 rows=1 width=81)
>>   InitPlan
>> rows=1 width=81)
>> (8 rows)
>> Robert W. Burgholzer
>> Surface Water Modeler
>> Office of Water Supply and Planning
>> Virginia Department of Environmental Quality rwburgholzer at deq.virginia.gov
>> 804-698-4405
>> Open Source Modeling Tools:
>> http://sourceforge.net/projects/npsource/
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
