[postgis-users] ST_Touches and line segment
Martin Davis mbdavis at refractions.net
Thu Mar 19 10:24:14 PDT 2009
I've had some thoughts that it would be nice to extend the concept of
Intersection Matrix Pattern to allow OR combinations of patterns.  This
seems to indicate that it's also necessary to be able to specify
different patterns for different combinations of geometry dimension.
Perhaps a syntax like:
"PP:***-*1*-*** LL:1***-***-*** PL:***-1**-***"
The LP pattern can be automatically inferred from this.
Note that I'm also using a "dashed triplet" syntax, which is more
readable than a solid string of 9 chars (think phone numbers or IP
addresses)
Kevin Neufeld wrote:
>>> If you have overlapping polygons then use ST_Relate with a custom
>>> matrix.  IE. ST_Relate(g1, g2, '****1****') will return TRUE for all
>>> geometry pairs where the intersection of the boundaries occur on a
>>> line (1).
>> You need to know the type of the input geometries.   The above
>> pattern will work for polygons, but not for lines.  The L/L and P/L
>> situation require different patterns:
>> L/L: 1********
>> P/L: ***1*****
> Ah, yes, of course :)
> The symmetric relation is also true:
> L/P: *1*******
> -- Kevin
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
