[postgis-users] ST_Touches and line segment
Kevin Neufeld kneufeld at refractions.net
Thu Mar 19 11:05:15 PDT 2009
That might be a nice expansion (or as an array list) - I know I've come across situations where it would have been useful.
Or/And, you could provide some routines that return TRUE on successful pattern matches, ie.
ST_MatrixMatches('101-F00-FF2','1TT-F*T-***').  In the same manner, one would only compute relate once (presumably in a
subquery) and then compare the matrices.
-- Kevin
Martin Davis wrote:
> I've had some thoughts that it would be nice to extend the concept of
> Intersection Matrix Pattern to allow OR combinations of patterns.  This
> seems to indicate that it's also necessary to be able to specify
> different patterns for different combinations of geometry dimension.
> Perhaps a syntax like:
> "PP:***-*1*-*** LL:1***-***-*** PL:***-1**-***"
> The LP pattern can be automatically inferred from this.
> Note that I'm also using a "dashed triplet" syntax, which is more
> readable than a solid string of 9 chars (think phone numbers or IP
> addresses)
> Kevin Neufeld wrote:
>>>> If you have overlapping polygons then use ST_Relate with a custom
>>>> matrix.  IE. ST_Relate(g1, g2, '****1****') will return TRUE for all
>>>> geometry pairs where the intersection of the boundaries occur on a
>>>> line (1).
>>> You need to know the type of the input geometries.   The above
>>> pattern will work for polygons, but not for lines.  The L/L and P/L
>>> situation require different patterns:
>>> L/L: 1********
>>> P/L: ***1*****
>> Ah, yes, of course :)
>> The symmetric relation is also true:
>> L/P: *1*******
>> -- Kevin
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
