[postgis-users] postgis on postgresql 8.2 vs 8.3
Obe, Regina robe.dnd at cityofboston.gov
Wed Mar 25 04:14:31 PDT 2009
Steve,
Just to add my 2 cents.  I've been running 8.3 on 2  production systems
for about 6-8 months now.  Aside from the index issue Mark already
mentioned, and also a bbox issue (with cached bboxes not always being
recalculated -- hmm I think this is fixed in 8.3.6 -- though I'll need
to verify) , I haven't run into any issues as far as PostGIS is
concerned.
However -- I think the biggest problem that people run into when
upgrading from 8.2 to 8.3 is that they took out a lot of autocasting
behavior so if you did things like assuming boolean can be treated as 1
and were less than careful with dates and numbers I forget the others
you may run into issues.  So you may want to test some of your apps in a
test mode first before blindly upgrading. (Sorry to scare you like
that).  I haven't run into such issues myself since the apps I have in
8.3  started out in 8.3.  I have yet to go back and upgrade my other
apps running on an 8.2 install.
As far as what you get with upgrading and things to watch out for, I
think its pretty well summarized here if you haven't already taken a
look
http://www.postgresql.org/docs/8.3/static/release-8-3.html
Although I'm almost tempted to say if you haven't upgraded yet you might
just want to wait for 8.4.  8.4 has all the major earth shattering
enhancements in it without any additional fuss (as there was with 8.3 --
e.g removal of casting change that breaks apps) so you only need to test
your apps once. Can't wait for that to officially come out.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Stephen Woodbridge
Sent: Tuesday, March 24, 2009 11:21 PM
To: PostGIS Users Discussion
Subject: [postgis-users] postgis on postgresql 8.2 vs 8.3
Hi all,
I have been holding back on upgrading my postgis installations from
postgresql 8.2 to 8.3 because:
1) it seemed like there was a lot of new postgresql stuff to figure out
in 8.3. What are the big changes I need to be aware of?
2) it seemed like there were initially some bugs and issues in
postgresql 8.3 that I'm guessing have mostly been resolved
3) seemed like there have been or still are some postgis issues when
running on postgresql 8.3
Is postgis and 8.3 safe and stable? are there specific bugs I need to be
aware of? Do we have a list somewhere and work-arounds?
On my Debian box, I installed postgresql 8.2 long ago and have just held
onto it, but the packages are no longer available in the archives and
sometime later I added liblq5-dev package which appears to have come
from 8.3 which is causing me headaches.
I can upgrade to 8.3, does this require a dump and restore, or is there
a hot upgrade for postgis databases?
I can try and find a debian postgresql-8.2 source package and see if I
can build the .deb files from that, but it seems like I will like need
to upgrade to 8.3 regardless at some point.
So I looking for advice, feedback, whatever.
Thanks,
   -Steve
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
