[postgis-users] reparing invalid geometry (polygon defined byoneor two points)
Ivan Mincik ivan.mincik at gmail.com
Wed Mar 25 04:54:23 PDT 2009
Yes, we use on that server very old PostGIS.
"POSTGIS="1.1.6" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.6.0, 21 Dec 2007" USE_STATS"
The most important reason to repair these geometries is that we want to upgrade to PostgreSQL 8.3  and current PostGIS. According to my tests, it is impossible to dump back these invalid geometries to newer PostgreSQL/PostGIS environment.
Maybe Geos 3.x is refusing them. I do not know now.
And Yes, You are right, in current version of PostGIS Your function will return correct geometry. In our old  PostGIS (1.1.6), the result is blank.
Ivan
On Wednesday 25 March 2009, Obe, Regina wrote:
> Ivan,
> Which version of PostGIS are you running?
> Do a:
> SELECT postgis_full_version();
> to have it return.
> When I run your below query, it returns a polygon that looks like this
> POLYGON((-266469.87 -1233431.41,-266423.25 -1233425.84,-266423.23 -1233426.17,-266422.74 -1233434.54,-266422.75 -1233439.44,-266425.68 -1233439.9,-266457.02 -1233444.89,-266463.17 -1233437.07,-266463.27 -1233436.29,-266469.15 -1233437.08,-266469.84 -1233431.65,-266469.87 -1233431.41),(-266463.92 -1233431.02,-266463.01 -1233431.01,-266463 -1233431,-266463.92 -1233431.02),(-266459.41 -1233430.46,-266458.67 -1233436.67,-266451.29 -1233435.76,-266451.1 -1233437.26,-266438.9 -1233435.75,-266439.07 -1233434.35,-266426.37 -1233432.65,-266427.07 -1233426.46,-266439.85 -1233428.04,-266459.41 -1233430.46))
> Although if your table requires multipolygons which I suspect it does, you'll want to wrap in a ST_Multi like
>  SELECT AsText(ST_Multi(BuildArea(Collect(b.final_geom)))) as filtered_geom
>  FROM (SELECT MakePolygon((/* Get outer ring of polygon */
>                SELECT ExteriorRing(a.the_geom) as outer_ring /* ie
> the outer ring */
>                ),  ARRAY(/* Get all inner rings > a particular area */
>                 SELECT ExteriorRing(b.geom) as inner_ring
>                   FROM (SELECT (DumpRings(a.the_geom)).*) b
>                  WHERE b.path[1] > 0 /* ie not the outer ring */
>                    AND (NPoints(b.geom) > 2 AND IsClosed(b.geom))
>                ) ) as final_geom
>         FROM (SELECT g.geom As the_geom
> FROM Dump(geomFromText('MULTIPOLYGON(((-266469.87
> -1233434.54,-266422.75 -1233439.44,-266425.68 -1233439.9, -266457.02
> -1233431.02, -266463.00 -1233431.00, -266463.01 -1233431.01,
> -266463.92 -1233431.02), (-266459.41 -1233430.46,-266458.67
> -1233426.46, -266439.85 -1233428.04,-266459.41 -1233430.46)))')) As g
>     WHERE NPoints(g.geom) > 2 AND IsClosed(g.geom)
>               ) As a
>       ) As b
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ivan Mincik
> Sent: Wednesday, March 25, 2009 4:37 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] reparing invalid geometry (polygon defined byoneor two points)
> Thanks for Simon's blog, I have found very interesting things there.
> I hope I understand what's going on in that function, but I always get
> empty geometry result.
> As test I tried following:
>  SELECT AsText(BuildArea(Collect(b.final_geom))) as filtered_geom
> the outer ring */
>                ) ) as final_geom
>               ) a
>       ) b
> Result is empty geometry. After removing  both IsClosed conditions
> geometry will appear. Why ? Where can be mistake ?
> Ivan
> On Tue, Mar 24, 2009 at 1:24 PM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> > Ivan,
> > Oops more of a variant.   I see you have invalid polygons as well not
> > just rings.  Hmm try this instead.  I didn't check my logic, but
> > hopefully you get the idea if this doesn't compile.
> > This is a bit of overkill if you have no multipolys with invalid rings.
> > But I'll leave as an exercise for you to figure out the simpler variant
> > if you need it.
> > CREATE OR REPLACE FUNCTION remove_invalidpoly(geometry)
> >  RETURNS geometry AS
> > $BODY$
> > SELECT ST_BuildArea(ST_Collect(b.final_geom)) as filtered_geom
> >  FROM (SELECT ST_MakePolygon((/* Get outer ring of polygon */
> >                SELECT ST_ExteriorRing(a.the_geom) as outer_ring /* ie
> > the outer ring */
> >                 SELECT ST_ExteriorRing(b.geom) as inner_ring
> >                   FROM (SELECT (ST_DumpRings(a.the_geom)).*) b
> >                    AND (ST_NPoints(b.geom) > 2 AND ST_IsClosed(b.geom))
> >                ) ) as final_geom
> > FROM ST_Dump($1) As g
> >     WHERE ST_NPoint(g.geom) > 2 AND ST_IsClosed(g.geom)
> >               ) a
> >       ) b
> > $BODY$
> >  LANGUAGE 'sql' IMMUTABLE;
> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Obe,
> > Regina
> > Sent: Tuesday, March 24, 2009 8:14 AM
> > Subject: RE: [postgis-users] reparing invalid geometry (polygon defined
> > byoneor two points)
> > Ivan,
> > I think a variant of Simon's script would work for you except instead of
> > keeping rings with a large enough hole, keep rings that are closed and
> > have enough points
> > http://www.spatialdbadvisor.com/postgis_tips_tricks/92/filtering-rings-i
> > n-polygon-postgis
> > so something like
> > CREATE OR REPLACE FUNCTION remove_invalidrings(geometry)
> >  RETURNS geometry AS
> > $BODY$
> > the outer ring */
> >                ) ) as final_geom
> >         FROM (SELECT ST_GeometryN(ST_Multi($1),/*ST_Multi converts any
> > Single Polygons to MultiPolygons */
> > generate_series(1,ST_NumGeometries(ST_Multi($1)))
> >                                   ) as the_geom
> >               ) a
> >       ) b
> > $BODY$
> > Hope that helps,
> > Regina
> > Mincik
> > Sent: Tuesday, March 24, 2009 5:03 AM
> > Subject: [postgis-users] reparing invalid geometry (polygon defined by
> > oneor two points)
> > Dear PostGIS users,
> > we have quite huge MULTIPOLYGON database table containing some 3
> > percents of invalid geometries.
> > Most problematic to repair are MULTIPOLYGONs which often contain polygon
> > defined by one or two points.
> > Example is here (second polygon is defined by one point):
> > MULTIPOLYGON(((-266469.87 -1233431.41,-266423.25 -1233425.84,-266423.23
> > -1233439.9,
> > -1233431.41),(-266463.92 -1233431.02),
> > It is not possible to run buffer(0) or many other functions on these
> > geometries because of "POSTGIS2GEOS conversion failed" (no suprise in
> > case of such non-sense geometry).
> > Is there any possibility how to repair them directly in database?
> > Thanks
> > Ivan
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > The substance of this message, including any attachments, may be
> > confidential, legally privileged and/or exempt from disclosure
> > pursuant to Massachusetts law. It is intended
> > solely for the addressee. If you received this in error, please
> > contact the sender and delete the material from any computer.
