[postgis-users] PostgreSQLdoesn't see my PostGIS plug-in
Paul Ramsey pramsey at opengeo.org
Wed Mar 25 07:44:06 PDT 2009
Mark,
Since everything you've described and should work, yes, in some matter
you're doing something wrong. But you haven't given enough details for
anyone to say exactly what. What commands are you running, start to
finish? What are the errors that you see?
P
On Wed, Mar 25, 2009 at 3:30 AM, Mark Fenbers <Mark.Fenbers at noaa.gov> wrote:
> Hello,
> I've configured/compiled/installed PostGIS with GEOS, Proj, and pgsql.  But
> how do I get PostgreSQL to know the plug-in now exists?  I've run the SQL
> that creates the geometry_columns and all the geometry functions, but yet
> whenever I run a query that involves a library function from liblwgeom.so, I
> get a complaint that the function is not available.  So I must be doing
> something wrong.
> Any ideas?
> Mark
> postgis-users mailing list
