[postgis-users] ST_Intersects and NOT ST_Disjoint aren't equal?
Gerrit Hoven gerrit.hoven at fh-gelsenkirchen.de
Thu Mar 26 06:22:42 PDT 2009
Hello Postgis Users
I was wondering about the behavior of ST_Disjoint and ST_Intersects.
My data is a 3D citymodel which is stored in "tbl_surface". There is the
geometry column "geom".
Normally I expect the same behavior of "WHERE ST_Intersects(...)" and
"WHERE NOT ST_Disjoint(...)"
But look what happens if I try to get everything inside a huge boundingbox:
Query A:
select geom from tbl_surface where
ST_Intersects(ST_GeomFromText('Polygon((0 0, 9999999 0, 9999999 9999999,
0 9999999, 0 0))'), geom)
returns 98524 rows, which I expect because this is all my data and the
boundingbox covers them all
Query B:
select geom from tbl_surface where not
ST_Disjoint(ST_GeomFromText('Polygon((0 0, 9999999 0, 9999999 9999999, 0
returns: 61895 rows (should be 98524 ???)
Query C:
returns: 36629 rows (should be 0 ???)
All my geometries are polygons which have z-coordinates.
There exist polygons (like walls), which when projecting them to the x-y
plane, are only lines. I think this is a hint for the strange behavior
of ST_Disjoint. Just look what the query results look like:
This is all my data:
http://81.89.98.151/Picture/queryA.png
This is everything inside the big box, using NOT ST_Disjoint. All the
polygons that are not a line in 2D
http://81.89.98.151/Picture/queryB.png
This is everything "outside" the big box, using ST_Disjoint. All the
polygons that are lines in 2D
http://81.89.98.151/Picture/queryC.png
Can anybody explain this to me? Or is it a bug.
Regards,
Gerrit
