[postgis-users] problem with plpgsql function - ERROR: could not open relation with OID XXX
Birgit Laggner birgit.laggner at vti.bund.de
Mon Mar 16 12:24:25 PDT 2009
Hi Leo,
with your TRUNCATE and ALTER SEQUENCE method, I still get an error at
polygon 451, but a new one:
ERROR: missing chunk number 0 for toast value 27366 in pg_toast_26963
SQL Status:XX000
Kontext:PL/pgSQL function "_laggner_b_pgdifference_a" line 63 at RAISE
I think, this describes the problem better then the oid referencing
error. As a result of a Google search, I got the impression that there
might be a corrupted row (polygon 451) in the database table. Any
suggestions how to solve the problem?
Thanks,
Birgit.
Birgit Laggner wrote:
>Hi Kevin,
>to define the table name in question as a variable did not work,
>unfortunately. I get the same error message as before. Now, I will try
>the TRUNCATE and ALTER SEQUENCE method of Leo...
>Regards, Birgit.
>>Thanks, Kevin and Leo! I will try your suggestions today.
>>Birgit.
>>Kevin Neufeld wrote:
>>> Yeah, I agree.  What I've done to get around the caching problem that
>>> seems to work is to define all table names as variables at the top of
>>> the function.  All the sql statements used throughout the function
>>> then reference a variable instead of an actual table.  The planner
>>> can't cache the query plan since the query is adhoc ... no OID
>>> referencing problem.
>>> -- Kevin
>>> Paragon Corporation wrote:
>>> Birgit,
>>> I suspect as you alluded to that you are a victim of the dreaded
>>> cached plan
>>> and your OID issue is because the new table doesn't have the same OID
>>> as the
>>> old table. 8.4 is supposed to be smart enough to invalidate plans in
>>> these
>>> situations, thought maybe not.
>>> One possible work around is instead of creating and dropping the
>>> table, why
>>> don't you just TRUNCATE the table and reset the sequence
>>> So something like
>>> TRUNCATE TABLE birgit.test_diff_dlm07_tmp;
>>> ALTER SEQUENCE birgit.test_diff_dlm07_tmp.gid RESTART WITH 1;
>>> You could also use CREATE TEMP TABLE instead of CREATE TABLE.  I suspect
>>> temp table oids may not be cached.
>>> Leo
>>> -----Original Message-----
>>> From: postgis-users-bounces at postgis.refractions.net
>>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>>> Birgit
>>> Laggner
>>> Sent: Thursday, December 03, 2009 12:26 PM
>>> To: PostGIS Users Discussion
>>> Subject: [postgis-users] problem with plpgsql function - ERROR: could
>>> not
>>> Dear list,
>>> I have written a pl/pgsql function (see below) for st_difference
>>> which in
>>> short should sequentially scan a geometric table (a) if there are
>>> intersections with geometric table (b) and if there are, it writes the
>>> intersecting polygons of table (b) into an extra table and then
>>> executes the
>>> st_difference for the actual polygon of table (a) and all polygons of
>>> table
>>> (b ) written in the extra table as a sequence always using the
>>> product of
>>> the last difference as the input (instead of the table (a)
>>> polygon) of the next difference. I hope everybody understands my way of
>>> thinking ;-)
>>> My problem is now, that at polygon 451 of table (a), the function
>>> stops with
>>> the following error message:
>>> ERROR: could not open relation with OID 25736 SQL Status:XX000
>>> Kontext:PL/pgSQL function "_laggner_b_pgdifference_a" line 67 at RAISE
>>> Strange is, that the function did run successfully for more than 100
>>> difference-loops. In an older PostGres version (8.1...), I have had a
>>> similar problem, but then always in the 2nd loop, because of the
>>> cashing-problem of the query planner.
>>> This are the PostGIS/PostgreSQL versions I am using:
>>> PostgreSQL: 8.4.1-2.1
>>> PostGIS: 1.4.0-10.1
>>> Here, the last few message rows of the running function, perhaps this
>>> helps
>>> with understanding the problem (sorry because it's partly in German,
>>> I hope
>>> it doesn't matter):
>>> NOTICE:  Beginn Difference für dlm07-Polygon 450
>>> NOTICE:  Anzahl Intersection-Polygone: 1
>>> NOTICE:  CREATE TABLE erstellt implizit eine Sequenz
>>> »test_diff_dlm07_tmp_gid_seq« für die »serial«-Spalte
>>> »test_diff_dlm07_tmp.gid«
>>> CONTEXT:  SQL-Anweisung »create table birgit.test_diff_dlm07_tmp (gid
>>> serial, inv07_id integer, the_geom geometry);« PL/pgSQL function
>>> "_laggner_b_pgdifference_a" line 39 at EXECUTE-Anweisung
>>> NOTICE:  recordset_object2a:
>>> (309108,0103000020EB7A000001000000220000009B8A50B33D3D4A410CFC87519141564121
>>> B29CCB563D4A4106E2E205904156415229B1B2773D4A41BE9861008E415641D117B6AD773D4A
>>> 41B9A76ADF6F4156410BF8A3EF3F3D4A41BD0E943870415641AFF9CD0B1D3D4A41BD0E943870
>>> 4156417CB35079F93C4A419BD797C96F41564178CEEED7F63C4A41E6DDA2F050415641D2D792
>>> 9CF53C4A41DF1DF01D46415641D5BD901CAE3C4A41F8BCF27D464156415E242F79AD3C4A4142
>>> 690C973A4156419B31B5B3893C4A41BA142C323341564105B615097B3C4A4170493851304156
>>> 41D1ABC0367F3C4A41000000002B4156415FC001E8EB3B4A41000000002B41564163BDF058E9
>>> 3B4A415E78DD7F2D4156417B1DF30FE43B4A4108E03B8E324156412AD0C960063C4A419F2015
>>> 233A41564114F5B712333C4A41DA07856543415641A34C690B4D3C4A41F4AF672C49415641EE
>>> 6CACD25B3C4A41A76FFFEE4C4156412B1572B3653C4A4194013F074F4156417A6F642C703C4A
>>> 41ED905744544156416FED9E4A833C4A417BFF4EB75F41564133189B64913C4A4111FD983366
>>> 4156419FF0E035993C4A4127C0195969415641E9615636B93C4A41F746505974415641125009
>>> 96C43C4A41609FC0987841564123E75FD9CE3C4A418FDC793F9141564183752A27DB3C4A418B
>>> 99EA269041564192DE2C6CFB3C4A41C198D3C29041564174C52E98113D4A41BB824C8F914156
>>> 41579F17352D3D4A41AF447FC5914156419B8A50B33D3D4A410CFC875191415641,1)
>>> NOTICE:  recordset_object1:
>>> (450,0103000020EB7A00000100000022000000CC72F1149A3C4A41000000002B415641295C8
>>> F229A3C4A4185EB51582B4156413E0AD7A3983C4A41000000002B415641351D7C68833C4A410
>>> 00000002B415641F6285C2F7E3C4A410000001031415641B81E856B913C4A41A4703D6A35415
>>> 6413E0AD723AD3C4A41AE47E17A3B415641B81E850BAE3C4A4114AE47E13E415641E17A144EA
>>> F3C4A417B14AEE74341564152B81EA5B03C4A410AD7A3B04741564114AE4721BB3C4A41EC51B
>>> 82E474156417B14AE67CC3C4A41AE47E17A46415641B81E852BD83C4A411F85EB01464156416
>>> 6666646D73C4A4185EB51B8454156413E0AD783D63C4A41666666664541564114AE4761D53C4
>>> A41B81E85DB44415641295C8F02D53C4A418FC2F548444156413E0AD703D53C4A41666666C64
>>> 34156419A999979D53C4A41AE47E1CA424156410AD7A330D63C4A41713D0AA741415641A4703
>>> D8AD73C4A41B81E859B40415641A4703DEAD93C4A41E17A14CE3E415641713D0A17DB3C4A41B
>>> 81E85DB3D415641CDCCCC8CDC3C4A41F6285CAF3C415641E17A148EDF3C4A41AE47E10A3B415
>>> 6419A999959E13C4A410AD7A3103A4156413E0AD7E3E23C4A4148E17AC438415641A4703D0AE
>>> 43C4A41AE47E13A38415641A4703DCAEB3C4A4114AE47213841564100000060EC3C4A413E0AD
>>> 7D33241564114AE47E1E03C4A41D7A370AD324156419A999979E33C4A417B14AE772E4156418
>>> 82F554CE43C4A41000000002B415641CC72F1149A3C4A41000000002B415641)
>>> NOTICE:  Intersection-Polygon 1 verarbeitet.
>>> NOTICE:  Difference-Polygon dlm07 450 ist fertig.
>>> NOTICE:  Beginn Difference für dlm07-Polygon 451
>>> (242405,0103000020EB7A00000100000093000000A5D6BC7F113B4A41DA9C414B8C44564150
>>> FAAEDD133B4A419F49202D8B4456412FF0D7391B3B4A41168EC19286445641E5C111791C3B4A
>>> 412DEE6FD88D44564193716BA71F3B4A41527950589B4456413706B5B4203B4A411CA7E1639F
>>> 4456417F264CED223B4A410BDF111DA544564195B45007273B4A410C80CF17AE445641233940
>>> 05293B4A41D9F53FC8B34456417B6AB9082D3B4A415F147142B4445641B5FC2FAC303B4A4129
>>> 35E853B4445641C323EFF1373B4A41C18C5DAAB34456412A8D25813F3B4A41C33BF4E5B24456
>>> 41022A8ED84C3B4A4118E6FF5DB2445641F237A3BB5D3B4A414C7E863FB244564191C9735265
>>> 3B4A410E9B8A5CB1445641529A25D6633B4A41C47E2DB7AD445641B5D7BDEA5E3B4A4160BF3D
>>> D7A4445641064DA2335A3B4A41B397823D9B445641468081F5693B4A412AAF71059B44564174
>>> 5B60647B3B4A4188667A919A4456411E7579487A3B4A41BA466E559944564131F2D4F87E3B4A
>>> 41C9563A27994456414A570C2C893B4A41CC1B91F797445641FAD2C8BCA33B4A419EEF661595
>>> 44564194F74682CE3B4A41C8A7A28090445641F677AA51E53B4A41C3AC804A8E4456419D16B3
>>> 33023C4A4145B4DB368B4456412CD4AE17083C4A4172F829968A4456418E660AAB223C4A4142
>>> 4103B9874456414F5B3AF4233C4A4100517DEF92445641F472B68E233C4A41C56C4F98934456
>>> 4102FCF859223C4A415E932D9A95445641EFCC195F113C4A41DB4F155BA64456415457E1A40E
>>> 3C4A4151BCC460A9445641115545C6083C4A41DC02CB19B14456418064136EF33B4A413F76BC
>>> D1AC445641DB6389DCF13B4A41BFE689EFB344564126807354EB3B4A4183EC2AACBD445641C5
>>> F5579DFA3B4A4121A624F3BF445641D717C6EBF73B4A41ABBB2195C744564161A21A04F33B4A
>>> 41FB77D15FD5445641D0D839DB053C4A41B7831098D84456410A907C33073C4A414244DACED0
>>> 44564148A334A9163C4A41547CEC36D1445641BF7B60D5363C4A41BCF33468D1445641F68B9D
>>> FE393C4A411283312ADA445641B45CC31A4C3C4A41F6A929D1D744564185C3D2CE563C4A4146
>>> BC02D9D64456410E266F8E503C4A41256BD10AC544564178A04D1C4E3C4A416E50306BBD4456
>>> 417ED898E54C3C4A41A3F1EA24B6445641C11890CB4D3C4A4185584DDFAE445641100E678C50
>>> 3C4A41447D8CC1A8445641C8EA7258533C4A41D025F919A4445641F45E60645B3C4A41F11D11
>>> 5B9B445641769EB3136B3C4A41DD06E5858D44564175B35E1A703C4A41CBE002D8874456418E
>>> E0827A743C4A41A399728D80445641C2DE7203773C4A4116C1F4C579445641BF3B192A783C4A
>>> 41250884A571445641B465A72D773C4A41317A276E5C4456414FFAB66E6C3C4A41EE3D4D3554
>>> 445641D8E3F8AF613C4A41CC142A074A445641C4DD74D9493C4A41E18223504A44564149E72F
>>> 02203C4A416083AE4C4B445641BB020316163C4A417AD8A6804D44564115A108B7023C4A4133
>>> B9970352445641667D32D4FA3B4A413B9DE3AB52445641206FE7D0EF3B4A410F12217D524456
>>> 416EAA545EE83B4A41E4AAF88E51445641C242D969DD3B4A41BC9873F84F44564159773A65CF
>>> 3B4A410D0595C04B445641B4F85B10CF3B4A4187C6CA374A445641883CC8C0C73B4A419A306D
>>> 07464456419595327EBB3B4A41A5F9E0843F445641A4113DFEA83B4A4120D2EB1E3644564157
>>> 6BBF8A9D3B4A41334EA22D30445641F52DD12E9C3B4A411BEEF45232445641A4E92DF3973B4A
>>> 413F90FFD13444564143331E7A943B4A41F761391136445641A69D4CB1903B4A414DC4100837
>>> 445641267AE7258C3B4A41A46AA98B37445641AFD254247C3B4A41E986946E384456417541D6
>>> 286D3B4A416D1F52DB3944564158B4E7076B3B4A412A3AF20F3A4456419F2AFEC4623B4A4145
>>> 0828DC3A44564109C6A7D5613B4A416D1F52DB39445641E9BFB312583B4A413FC197913B4456
>>> 4137F356324D3B4A4145E438BF3E445641A69714F4243B4A41FF1C9DC249445641F8194AC213
>>> 3B4A4129F0221B4F445641FA42FB2D133B4A41A2CCF75B54445641616D3114153B4A419CB61B
>>> 4C58445641BF8B0E1D183B4A418E3130FA5B4456415BD1C57B1F3B4A41AE6C11205E445641EB
>>> C43854353B4A4112AAE30063445641F4DE50CD423B4A41B562C8B96C4456417E0F5D25413B4A
>>> 41BA301B6C6D445641CBDFD71D343B4A41E66F8A9663445641805C16E81C3B4A41F872CAAB5E
>>> 445641433BF7F3173B4A41BAB368095D4456413F29FF2F143B4A41D805CA755A445641C55526
>>> D1103B4A4158A7F41B554456415BF92622113B4A41885AA7994F4456416402759FF53A4A4116
>>> 623BE750445641F6FFBDB0F23A4A415EB061555044564131A5403BE93A4A418CC63CFA4C4456
>>> 412FFBA344E43A4A418D36F0724C4456415DB86386B33A4A41BFA5FE494D445641A5FD702CAD
>>> 3A4A417D8DBFBC4D445641A2967FC9A33A4A41E508260650445641FAC39BD16C3A4A419ABBC1
>>> 1F5F445641E2C7B9E9683A4A413EFFA1685F44564170F2B498613A4A41F872CAAB5E44564192
>>> C7B713423A4A41D76C65915B445641F5A23B242A3A4A41F4F96F2D5A445641DAD3B5921B3A4A
>>> 4168628F5858445641AF0DF4EC133A4A41F038A8CC56445641807AF58D0D3A4A41F80F4C3D56
>>> 445641641AB90A073A4A412046A47557445641764EC9D5013A4A417192BBD758445641C1CD4D
>>> 37FE394A418E16E7775B445641E07DDC1AFA394A418AE5C1E55E445641783329A1F1394A411E
>>> EC95816444564171FF88C2E8394A41BB6F1AAA694456411A500F6DD9394A414D459052724456
>>> 4160B99CAEE8394A41D4C6E9F3744456411E15301DF4394A41E6F51C60794456416CD799DEF7
>>> 394A41A3D453B37A4456411D105594103A4A41CC5FFA667E44564136C98BE8183A4A4147B127
>>> 89804456414A49D33C213A4A41B381F8C8814456414633A250283A4A41AA794B418244564122
>>> 3F70313C3A4A415F233FEA82445641B5899402483A4A410904F70B8344564117DDEFEC5C3A4A
>>> 41E541706483445641E6247DF6713A4A417E1B589683445641A219CD66933A4A41372C3C3784
>>> 44564146FD76AECD3A4A41F5171BC28644564129A670D9D23A4A41BB8934F98744564136C565
>>> B1D63A4A4104824C3A89445641265EE8E6E03A4A41B0E45ABC8D44564141F89B25EA3A4A416D
>>> 9A8BC792445641E1B6AC97EC3A4A41EE52A9E19444564164801FAAFA3A4A414E05B8289A4456
>>> 41A5D6BC7F113B4A41DA9C414B8C445641,1)
>>> (451,0103000020EB7A00000100000007000000F6285CEF5D3C4A413E0AD7134A445641D7A37
>>> 0DD733C4A411F85EB0159445641C2F5283C7C3C4A413E0AD72359445641EC51B8FE7A3C4A41D
>>> 7A370FD47445641EC51B8FE733C4A413E0AD76348445641713D0A57663C4A418FC2F54849445
>>> 641F6285CEF5D3C4A413E0AD7134A445641)
>>> CONTEXT:  PL/pgSQL function "_laggner_b_pgdifference_a" line 67 at RAISE
>>> If anybody has suggestions, I would be very happy. If you need more
>>> information or the two tables in question, please tell me.
>>> Many thanks,
>>> Birgit.
>>> CREATE OR REPLACE FUNCTION _laggner_b_pgdifference_a()
>>>   RETURNS void AS
>>> $BODY$
>>>  DECLARE
>>>   counter            integer;
>>>   recordset_object1  RECORD;
>>>   recordset_object2  RECORD;
>>>   recordset_object2a  RECORD;
>>>   recordset_object3  RECORD;
>>>   i                  integer;
>>>   n                  integer;
>>>   j                  integer;
>>>   m                  integer;
>>>  BEGIN
>>>        --4. Difference a (dlm07):
>>>  counter := 0;
>>>  i := 0;
>>>  n := count(dlm07_id) from birgit.ni_dlm07_clip2;
>>>  FOR i in 1..n LOOP --LOOP 1
>>>  RAISE NOTICE 'Beginn Difference für dlm07-Polygon % ', i;
>>>  SELECT dlm07_id, the_geom INTO recordset_object1 from
>>> birgit.ni_dlm07_clip2 where dlm07_id=i;
>>>  SELECT b.inv07_id as inv07_id, b.the_geom as the_geom INTO
>>> recordset_object2
>>>   from birgit.ni_dlm07_clip2 a,
>>>        birgit.ni_inv07_clip2 b
>>>   where a.dlm07_id=i and
>>>         st_relate(a.the_geom, b.the_geom, '2********');
>>>  m := count(recordset_object2.inv07_id);
>>>  RAISE NOTICE 'Anzahl Intersection-Polygone: % ', m;
>>>  IF m > 0  THEN
>>>  execute
>>>  'create table birgit.test_diff_dlm07_tmp (gid serial, inv07_id integer,
>>> the_geom geometry);';
>>> insert into birgit.test_diff_dlm07_tmp (inv07_id, the_geom)
>>>   select recordset_object2.inv07_id, recordset_object2.the_geom;
>>>  SELECT a.inv07_id as inv07_id,
>>>         a.the_geom as the_geom,
>>>         a.gid as gid
>>>   INTO recordset_object2a
>>>   FROM birgit.test_diff_dlm07_tmp a;
>>>  RAISE NOTICE 'recordset_object2a: %', recordset_object2a;
>>>  execute
>>>  'drop table birgit.test_diff_dlm07_tmp;';
>>>  j := 0;
>>>  FOR j in 1..m LOOP --LOOP 2
>>>  RAISE NOTICE 'recordset_object1: %', recordset_object1;  RAISE NOTICE
>>>  SELECT recordset_object1.dlm07_id as dlm07_id,
>>> st_difference(recordset_object1.the_geom,
>>> recordset_object2a.the_geom) as
>>> the_geom
>>>   INTO recordset_object3
>>>   WHERE recordset_object2a.gid=j;
>>>  SELECT recordset_object3.dlm07_id as dlm07_id,
>>> recordset_object3.the_geom
>>> as the_geom INTO recordset_object1;
>>>  RAISE NOTICE 'Intersection-Polygon % verarbeitet. ', j;
>>>  END LOOP; --END LOOP 2
>>>   IF st_isempty(recordset_object1.the_geom)='f' then
>>>   INSERT INTO birgit.test_diff_dlm07 (dlm07_id, inv07_id, the_geom)
>>>    VALUES (
>>>     recordset_object1.dlm07_id,
>>>     NULL,
>>>     recordset_object1.the_geom);
>>>   END IF;
>>>  RAISE NOTICE 'Difference-Polygon dlm07 % ist fertig. ', i ;
>>>  ELSE RAISE NOTICE 'Kein Difference berechnet. ';
>>>  END IF;
>>>  counter := counter + 1;
>>>  END LOOP; --END LOOP 1
>>>  END;
>>> $BODY$
>>>   LANGUAGE 'plpgsql' VOLATILE;
>>> ALTER FUNCTION _laggner_b_pgdifference_a() OWNER TO postgres;
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
