[postgis-users] Correct use of ST_Transform
benton101 Ben.Davies at dec.wa.gov.au
Tue May 5 00:19:12 PDT 2009
>It should do if the data going in has the right SRID.
Simon,
Thank You for your help, I cannot work out what is going on, I have tested
the records in the tables to ensure that they are in the coords that I
expect, but when I carry out the insert statement it retains the original
SRID. I will have to continue looking at this problem.
I used some code like this to see what would be returned from the tables I
have.
SELECT gid
     , st_x(st_transform(the_geom, 4283))
     , st_y(st_transform(the_geom, 4283))
  FROM spl_parcels_point
 ORDER BY gid ASC;
Ben
View this message in context: http://www.nabble.com/Correct-use-of-ST_Transform-tp23380852p23382301.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
