[postgis-users] Long query execution time - is it OK?
Paul Ramsey pramsey at opengeo.org
Tue May 5 21:03:47 PDT 2009
It seems slower than I might expect. Is your table really wide? (100s
of columns, or some really big objects?) If the rows are all toasted
that would make updates and reads both a good deal slower.
P
On Tue, May 5, 2009 at 8:40 PM, Ben Madin <ben at remoteinformation.com.au> wrote:
> G'day all,
> I realise that there are probably many reasons, but I have a table with
> about 4 million tuples reflecting start and end point id's over two years.
> I haven't been able to workable join these on the fly, so I have added three
> columns, one for the geometry of the start point, one for the geometry of
> the end point, and one for the (direct) line between them.
> I then updated the start and end point columns (took around 20 minutes for
> each) by a UPDATE ... FROM ... JOIN syntax.
> then this morning reduced the fillfactor of the table to 50% to try to make
> writes easier and I used st_makeline to create the third geometry (the
> line). the query plan didn't look very complex (unfortunately I didn't
> explain analyze):
> update nlis set line_geom = st_makeline(s_geom, d_geom) where s_geom is not
> null and d_geom is not null;
>                           QUERY PLAN
>  Seq Scan on nlis  (cost=0.00..194364.48 rows=3654306 width=246)
>   Filter: ((s_geom IS NOT NULL) AND (d_geom IS NOT NULL))
> (2 rows)
> UPDATE 3701850
> duration: 1 743 563.733 ms
> Is 30 minutes reasonable for this sort of query?
> I have increased max_connection, shared_buffers, effective cache size etc
> and kern.sysv.shmmax and kern.sysv.shmall and a few other tuning bits and
> pieces based on information at
> http://wiki.postgresql.org/wiki/Tuning_Your_PostgreSQL_Server. This is
> running on a 2.4 GHz Core Duo (Mac OS X) with 2GB RAM and I notice that the
> postgres process seems to only variably run between 10 and 45% of total CPU.
> Disk writes seemed to come in packets every few seconds, with nothing much
> in between.
> I could be worrying about nothing, but I see posts of people with millions
> and millions of records, so I guess I'm just checking.
> cheers
> Ben
> Ben Madin
> REMOTE INFORMATION
> t : +61 8 9192 5455
> f : +61 8 9192 5535
> m : 0448 887 220
> Broome   WA   6725
>                                                        Out here, it pays to
> know...
> postgis-users mailing list
