[postgis-users] value of spatial index on 300, 000, 000 point geometries
Paul Ramsey pramsey at opengeo.org
Tue May 5 23:04:10 PDT 2009
Well, our versions differ, but that means nothing :)
medford=# select postgis_proj_version();
 Rel. 4.6.1, 21 August 2008
(1 row)
I'm also running 1.4SVN. And I can't recall if I installed the grid shift files.
P.
On Tue, May 5, 2009 at 10:55 PM, Kevin Neufeld <kneufeld at refractions.net> wrote:
> :) So if proj doesn't have z transformation then ... I have a bogus proj
> install or corrupt spatial ref definition?
> postgis=# select postgis_proj_version();
>  postgis_proj_version  -------------------------
> Rel. 4.4.9, 29 Oct 2004
> (1 row)
> Since my answer is different than yours, something is amiss.
> Paul Ramsey wrote:
>> On Tue, May 5, 2009 at 9:58 PM, Kevin Neufeld <kneufeld at refractions.net>
>> wrote:
>>>  But (and folks can correct me if I'm wrong since the docs don't actually
>>> specify) transforms operate on *all* dimensions.
>>> postgis=# select st_asewkt(st_transform('SRID=3005;POINT(1240227 495643
>>> 5)',
>>> 4001));
>>>                            st_asewkt
>>> SRID=4001;POINT(-122.689717977579 49.4258574870912 533.550271589169)
>>> (1 row)
>> That's news to me and my version of PostGIS:
>> medford=# select st_asewkt(st_transform('SRID=3005;POINT(1240227
>> 495643 5)', 4001));
>>                       st_asewkt
>>  SRID=4001;POINT(-122.689717977579 49.4265525863074 5)
>> (1 row)
>> My intuition was that reprojection would leave Z alone, since proj4
>> has no z-transform capabilities.
>> P.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
