[postgis-users] (no subject)
rahul.pachaghare at tcs.com rahul.pachaghare at tcs.com
Wed May 13 00:03:29 PDT 2009
Hi..
I have created plgsql with the command
createlang plpgsql [yourdatabase]
Thank you.
Regards,
Rahul Pachaghare
Member,TEG Open Source
Tata Consultancy Services
Mailto: rahul.pachaghare at tcs.com
Website: http://www.tcs.com
____________________________________________
Experience certainty.   IT Services
                  Business Solutions
                  Outsourcing
             Anton Patrushev
             <anton at orkney.co.
             jp>                                                        To
             Sent by:                  PostGIS Users Discussion
             postgis-users-bou         <postgis-users at postgis.refractions.
             nces at postgis.refr         net>
             actions.net                                                cc
        Subject
             05/13/2009 12:25          Re: [postgis-users] (no subject)
             PM
             Please respond to
               PostGIS Users
                Discussion
             stgis.refractions
                   .net>
It looks like you forgot to create Pl/pgSQL language in your database.
Anton.
On Wed, May 13, 2009 at 3:26 PM,  <rahul.pachaghare at tcs.com> wrote:
> Hi,
> I am new to this and I am trying to install PostGIS -1.3.6.I have
followed
> the instructions upto createlang plpgsql..But for
> Now load the PostGIS object and function definitions into your database
by
> loading the lwpostgis.sql definitions file.
> # psql -d [yourdatabase] -f lwpostgis.
> I am getting a huge errors.The errors are as:
> psql:lwpostgis.sql:3295: ERROR:  current transaction is aborted, commands
> ignored until end of transaction block
> psql:lwpostgis.sql:3334: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3347: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3354: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3359: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3365: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3374: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3378: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3388: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3392: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3397: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3401: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3405: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3409: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3413: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3417: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3469: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3479: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3485: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3491: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3497: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3503: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3509: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3515: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3521: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3527: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3533: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3539: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3545: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3551: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3557: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3564: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3570: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3576: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3582: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3588: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3594: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3600: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3606: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3612: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3618: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3624: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3630: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3636: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3642: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3648: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3651: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3652: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3653: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3654: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3655: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3656: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3657: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3658: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3659: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3660: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3661: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3662: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3663: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3674: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3680: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3687: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3693: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3700: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3706: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3713: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3719: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3726: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3732: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3738: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3744: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3754: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3760: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3766: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3772: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3778: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3784: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3790: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3796: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3802: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3808: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3818: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3824: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3830: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3836: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3842: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3848: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3854: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3860: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3867: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3873: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3879: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3885: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3891: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3897: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3903: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3909: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3915: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3921: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3927: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3934: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3941: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3947: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3953: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3961: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3969: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3975: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3981: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3987: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3993: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3999: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4005: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4011: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4017: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4024: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4030: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4036: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4042: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4048: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4055: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4060: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4066: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4073: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4079: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4085: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4092: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4098: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4104: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4111: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4117: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4123: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4129: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4136: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4142: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4149: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4155: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4161: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4168: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4174: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4181: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4187: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4193: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4199: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4205: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4211: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4217: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4223: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4229: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4235: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4241: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4247: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4253: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4263: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4269: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4275: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4281: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4287: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4293: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4302: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4309: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4315: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4322: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4328: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4335: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4342: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4352: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4359: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4365: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4372: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4379: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4385: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4392: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4399: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4409: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4415: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4421: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4427: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4433: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4439: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4445: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4456: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4462: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4468: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4474: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4480: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4486: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4492: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4498: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4504: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4510: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4516: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4522: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4528: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4534: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4540: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4546: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4552: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4579: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4585: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4591: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4597: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4603: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4609: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4615: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4621: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4627: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4633: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4639: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4645: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4651: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4657: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4663: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4669: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4675: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4681: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4687: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4693: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4699: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4705: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4711: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4717: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4723: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4729: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4735: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4741: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4747: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4753: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4759: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4765: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4771: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4777: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4782: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4787: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4792: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4797: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4807: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4817: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4827: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4838: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4848: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4858: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4868: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4878: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4884: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4890: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4900: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4910: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4920: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4930: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4936: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4942: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4948: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4954: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4965: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4976: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4986: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:4996: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5002: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5008: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5014: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5020: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5030: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5040: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5050: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5060: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5066: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5072: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5078: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5084: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5090: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5100: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5110: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5120: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5130: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5136: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5142: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5148: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5154: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5165: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5176: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5187: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5198: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5204: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5210: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5216: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5222: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5232: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5242: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5252: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5262: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5272: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5282: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5292: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5302: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5312: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5322: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5332: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5342: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5352: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5362: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5372: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5382: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5392: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5402: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5412: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5422: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5432: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5442: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5452: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5462: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5472: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5482: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5492: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5502: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5512: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5522: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5532: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5542: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5552: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5562: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5572: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5582: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5592: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5602: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5612: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5622: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5632: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5642: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5652: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5662: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5673: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5684: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5695: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5706: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5749: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5778: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5814: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5838: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5882: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5933: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5940: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5947: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5954: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:5987: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6020: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6027: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6032: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6037: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6096: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6114: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6159: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6218: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6238: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6295: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6318: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6332: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6346: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6360: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6366: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6372: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6410: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6459: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6482: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6488: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6512: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6523: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6528: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:6533: ERROR:  current transaction is aborted, commands
> ROLLBACK
> Above is not the complete list of errors.....Anyone got any idea?
> Thank You in advance.
> Regards,
> Rahul Pachaghare
>                  Business Solutions
>                  Outsourcing
> Notice: The information contained in this e-mail
> message and/or attachments to it may contain
> confidential or privileged information. If you are
> not the intended recipient, any dissemination, use,
> review, distribution, printing or copying of the
> information contained in this e-mail message
> and/or attachments to it are strictly prohibited. If
> you have received this communication in error,
> please notify us by reply e-mail or telephone and
> immediately and permanently delete the message
> and any attachments. Thank you
> postgis-users mailing list
ForwardSourceID:NT00003A6E
