[postgis-users] Versioning
Ben Madin ben at remoteinformation.com.au
Wed May 13 14:47:53 PDT 2009
I might not have the best solution, but for some use cases this is one
of the key reasons we are using a database for GIS data. It isn't
perfect, so any feedback would be considered in a positive light.
Every record has a start and end validity - the end being null for the
most recent.
When new data is provided, we insert a new record, with the new start
validity, and put in an end validity for the old record (we also
record the user id who made the change)
This is a solution for the Multiple Areal Unit Problem for
jurisdictional boundaries (at some level), so not a huge number of
polygons, and for event data (as points)
Queries can then draw the appropriate polygon for the timing of the
data set. I'm new to dealing with it, but obviously there are problems
with some analyses where the boundary changes within the range of
times in a query.
Actually, this might not be a very good solution at all, but has
helped for now!
cheers
Ben
On 14/05/2009, at 4:26 AM, Juan Pedro Pérez Alcántara wrote:
> Sure, you right. I'm refering versioning in it's first meaning, that
> is,
> history tracking.
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
							Out here, it pays to know...
