[postgis-users] more centos install troubles
Paul McCullough paul.mccullough at sfgov.org
Tue May 19 16:05:49 PDT 2009
All,
When I do this
> yum install postgresql-devel
I get these errors
--> Finished Dependency Resolution
postgresql-devel-8.1.11-1.el5_1.1.x86_64 from base has depsolving problems
  --> Missing Dependency: libpgtypes.so.2()(64bit) is needed by package
postgresql-devel-8.1.11-1.el5_1.1.x86_64 (base)
  --> Missing Dependency: libecpg_compat.so.2()(64bit) is needed by package
  --> Missing Dependency: libpq.so.4()(64bit) is needed by package
postgresql-devel-8.1.11-1.el5_1.1.i386 from base has depsolving problems
  --> Missing Dependency: postgresql = 8.1.11-1.el5_1.1 is needed by package
postgresql-devel-8.1.11-1.el5_1.1.i386 (base)
  --> Missing Dependency: libecpg.so.5()(64bit) is needed by package
Error: Missing Dependency: libecpg.so.5()(64bit) is needed by package
Error: Missing Dependency: libpq.so.4()(64bit) is needed by package
Error: Missing Dependency: libecpg_compat.so.2()(64bit) is needed by package
Error: Missing Dependency: postgresql = 8.1.11-1.el5_1.1 is needed by
package postgresql-devel-8.1.11-1.el5_1.1.i386 (base)
Error: Missing Dependency: libpgtypes.so.2()(64bit) is needed by package
package postgresql-devel-8.1.11-1.el5_1.1.x86_64 (base)
[maddev:main.mad_db postgis-1.3.6]#
I a few other paths including
> yum install postgresql-devel.i386
> yum install postgresql-devel.x86_64
> yum install postgresql-contrib.x86_64
with more or less the same results
My system:
> cat /etc/redhat-release
CentOS release 5.3 (Final)
> uname -a
Linux mad_db 2.6.18.8-xenU #1 SMP Mon Aug 18 14:00:41 PDT 2008 x86_64 x86_64
x86_64 GNU/Linux
Without postgresql-devel I can't do this
> ./configure --with-pgsql=/usr/bin/pg_config
> --with-geos=/usr/local/bin/geos-config --with-proj=/usr/local
Thanks!
Paul
View this message in context: http://www.nabble.com/more-centos-install-troubles-tp23626022p23626022.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
