[postgis-users] Re: Coordinate changes using transform from 1.3.1 to 1.3.6
Miguel R. Luaces miguelrluaces at gmail.com
Tue May 26 02:16:54 PDT 2009
The query should be:
select nome, astext(the_geom), astext(transform(the_geom, 4326)) from
monumentos where id = 9;
Copy-paste mistake. The problem still remains...
Best regards,
  Miguel
On Tue, May 26, 2009 at 11:12 AM, Miguel R. Luaces
<miguelrluaces at gmail.com>wrote:
> Dear all,
> we have a PostgreSQL 8.1 database with postgis 1.2 installed. We have some
> data in the database stored using EPSG:23029.
> We make a backup with pg_dump and we restore the database in PostgreSQL 8.2
> with Postgis 1.3.1 without any problem.
> But, if we restore the backup in PostgreSQL 8.2 with Postgis 1.3.6, the
> function transform() returns a different result. More precisely:
> The same query:
> select astext(the_geom), astext(transform(the_geom)) from monumentos where
> id = ,
> In Postgis 1.3.1:
> "Castelo de San Antón";"POINT(549556.009066526
> 4801796.3531214)";"POINT(-8.38839299999999 43.3657910268222)"
> In Postgis 1.3.6:
> 4801796.3531214)";"POINT(-8.38839299999999 43.3666118995462)"
> The second coordinate of the transformation to 4326 changes by 0.004
> degrees (approx).
> Any idea?
> Thank you very much in advance.
> Best regards,
>   Miguel
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090526/92d90d5b/attachment.html>
