[postgis-users] ESRI GDB format into PostGIS
Simon Greener simon at spatialdbadvisor.com
Thu May 28 16:38:00 PDT 2009
Frank and Piotr,
Yes, Manifold has reverse-engineered Personal and Enterprise GeoDatabases. DOn't know how well.
Type "GeoDatabase" into Search in the Manifold Help.
But, the way it is done is that one uses Tools>Database Console tto go to the database (eg Access .mdb) file that holds the
geodata. When Manifold opens it it will recognise the ESRI crap and allow you to import/link to it.
regards
Simon
> Frank Warmerdam wrote:
>> Are you suggesting that Manifold GIS has reverse engineered the file
>> geodatabase format?  Can you provide any pointers supporting that?
>> If those guys can reverse engineer it, then so could we given enough
>> desire.
> I'm using Manifold on daily basis. Not to import ESRI files.
> Just looked through all possible imports and couldn't find ESRI GDB file
SpatialDB Advice and Design, Solutions Architecture and Programming,
Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
Website: www.spatialdbadvisor.com
  Email: simon at spatialdbadvisor.com
  Voice: +61 362 396397
Mobile: +61 418 396391
Skype: sggreener
Longitude: 147.20515 (147° 12' 18" E)
Latitude: -43.01530 (43° 00' 55" S)
NAC:W80CK 7SWP3
