[postgis-users] Combining / agglomerating / clustering numbers of adjacent polygons
Derek Jones scunacc at yahoo.com
Wed Nov 4 06:15:04 PST 2009
Dear Matias
Thanks for the thought. Any help is always appreciated.
I actually am using this agglomeration (when I eventually derive it  ;-)
) to seed kmedoids or kmean centroids for statistical clustering, (doing
it in R via a variety of methods to see what works best). I already have
a much larger set of points that need to be clustered around the set of
centroids I generate from this grid agglomeration process.
However doing this gridding and agglomeration process first gives me a
twofold advantage, in that it not only gives me the centroid for the
clustering of the "other" data set, but also allows me to identify the
actual spatial areas in which some of my (statistical) cluster points
(in the other data set) should fall to start with, so I will do at least
one level of spatial intersection, then one level of statistical
clustering on top.
I am at this point favoring doing the grid agglomeration
programmatically - perhaps I can get that done today. (Unless anyone
comes up with an SQL solution before I finish coding it up ;-))
I'll let you folks know if I make the programmatic approach work but I'm
still open to other input in the meantime.
Thanks to all for suggestions thus far.
Kind regards
Derek.
