[postgis-users] OpenStreetMap to GPS
Matthew Pulis mpulis at gmail.com
Sun Nov 8 12:52:57 PST 2009
Thanks alot :) the last part of the tutorial to load the 900913.sql really
wasn't useful then :) using the -l attributed helped the import to run
successfully! thanks guys
On Sat, Nov 7, 2009 at 11:28 PM, Emilie Laffray <emilie.laffray at gmail.com>wrote:
> Matthew Pulis wrote:
> > Guys,
> > I want to plot a list of GPS acquired locations with data originating
> > from OpenStreetMap. I am thinking to keep everything in GPS projection
> > since quite near in the future the project is going to be accepting
> > live GPS readings.
> > OSM SRID = 900913
> > Should I consider GPS SRID to be: 4326?
> It looks like you used osm2pgsql in its default mode. If you want to
> have data in 4326 with osm2pgsql, you have to use the flag -l.
> The default SRID for OSM is 4326. It is only osm2pgsql that is
> transforming this into 900913 for the rendering.
> Emilie Laffray
> postgis-users mailing list
Matthew Pulis
URL : http://www.matthewpulis.info | http://www.solutions-lab.net
MSN : pulis_matthew[@]hotmail.com
ICQ : 145951110
Skype : solutions-lab.net
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091108/defcf847/attachment.html>
