[postgis-users] Install postgis on a different schema
Kevin Neufeld kneufeld at refractions.net
Tue Nov 24 15:33:39 PST 2009
Hi Mark,
Yes, that's exactly why I wrote that function.  The idea is that whenever you restore a schema from backup or add/remove
numerous spatial tables to/from your database, you can quickly register them again with PostGIS.  This saves you the
headache of trying to backup a portion of the geometry_columns table (that which is relevant to the schema being backed up).
Also, the geometry_columns table hasn't always been stable, meaning the table structure has changed in the past.  So
then you'd have to contend with a mismatched restore script into a modified table. Yuk.
Nope, leave it to PostGIS to regenerate PostGIS metadata.  There's talk of turning this table into a view down the road
so this would all be a moot point anyway.
Cheers,
Kevin
MarkW wrote:
> Thanks Puneet - sorry for the confusion. I was referring to the
> "geometry_columns" table - I believe it's always in the public schema
> along with postGIS functions and not in each schema; I wonder if I need
> to worry about backing that up, or is this what one of the newer
> functions is for:
> http://postgis.refractions.net/documentation/manual-1.4/Populate_Geometry_Columns.html
> Mark
