[postgis-users] How to index GeometryCollections
Andreas Kalsch andreaskalsch at gmx.de
Thu Oct 1 12:36:30 PDT 2009
The query
"SELECT class, id FROM geoobject_geom
WHERE ST_Intersects(
    GeomFromText(?, 4326),
    geom
LIMIT 1000"
results in exception
"SQLSTATE[XX000]: Internal error: 7 ERROR:  Relate Operation called with
a LWGEOMCOLLECTION type.  This is unsupported"
1) When will the relation check functions support GeometryCollections as
arguments? This is even supported in MySQL ;)
2) Is the only way to index GeometryCollections to index many single
geometries?
Thanks,
Andi
