[postgis-users] polygon minimum width
Surya Tarigan surya.tarigan at yahoo.com
Thu Oct 1 20:15:46 PDT 2009
Hallo Nicklas
fortunately I have linestring version of the polygon, but it seems that the linestirings are not continuous. Does st_distance still apply? Or are there any postgis function to make the polyline continuous?
kind regards,
From: "nicklas.aven at jordogskog.no" <nicklas.aven at jordogskog.no>
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Sent: Thursday, October 1, 2009 3:50:37 PM
Subject: Re: [postgis-users] polygon minimum width
Hallo
I think the easiest way is to make a linestring of the polygon.boundary and then cut the line in the start and end so you get two more or less paralell lines. Then you can use st_distance to find the shortest distance between them.
Hope that helps
Nicklas
2009-10-01 Surya Tarigan wrote:
Dear list,
I  have a river polygon with polygon length about 20 km.  How can I query the minimum width of  the river polygon. I tried to search previous threads, but I could not find any clue.
kind regards,
surya
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091001/b3091eaa/attachment.html>
