[postgis-users] Optimal path with alternative paths
Supunmali Ahangama supunmali7 at gmail.com
Sun Oct 4 07:39:04 PDT 2009
hi,
I did an application get the optimal path using Dijkstra Algorithm in
pgrouting.
Now I need to get the optimal path and three other best possible alternative
paths (next three best options) between the same origin to the destination.
What is the way to do it?
Thanks in advance.
View this message in context: http://www.nabble.com/Optimal-path-with-alternative-paths-tp25738587p25738587.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
