[postgis-users] Install postgis on a different schema
Andrea Peri aperi2007 at gmail.com
Sun Oct 4 14:22:13 PDT 2009
I'm testing the Stephen's approach.
It work very well.
In effect with this solution it work very well .
Hovewer I'll try even to install postgis on different schema.
I like to know if is possible to install some version of postgis on
different schemas of the same database.
This knowledge can be useful when I need to backup and restore a
single schema even if the principal version of
postgis is changed.
Many thx for hints.
Andrea.
>Generally speaking I tend to follow
>Stephen's approach because the installing postgis in a non-public schema is
>not as tried and tested.
>I'm not even sure if there are any assumptions embedded in products that
>support postgis we don't know that assume postgis is in public.
>Aside from that -- there isn't any problem with that as long as you add the
>postgis schema to your database search_path.
>Hope that helps,
>Regina
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091004/85ef49c5/attachment.html>
