[postgis-users] point to list
Paragon Corporation lr at pcorp.us
Sun Oct 11 07:38:05 PDT 2009
Try
SELECT n As id, ST_PointN(ST_Boundary(the_geom),n) As the_geom
FROM (SELECT ST_GeomFromText('POLYGON ((0 0, 0 1, 1 1, 1 0, 0 0))' ) as
the_geom) As foo
CROSS JOIN generate_series(1, 10000) As n
WHERE n  < ST_NPoints(the_geom)
1) The above will only work with POLYGONS that don't have holes.  If you
have holes then you have to decide how you will store the id for the holes.
Also if you have polygons, you'll need to dump them first.
2) you need to set 10000 to a number greater than the number of points you
have in any particular polyon.  so to figure that out
3) The foo subquery you can replace with any table
SELECT MAX(ST_NPoints(the_geom))
FROM yourtable
Leo
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of eehab
hamzeh
Sent: Sunday, October 11, 2009 8:13 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] point to list
Hello
i try to have the points that make one polygon in one table as follow.
i have the following polygon
polygon (0 0, 0 1, 1 1, 1 0)
i need it to be in a table where the results looks like
1  :  point(0 0)
2  :  point(0,1)
3  :  point(1 1)
4  :  point(1,0)
i try to use st_dump(the geom) from polygon
it does not work
it is important to me to assign id for each point
thanks
Windows Live: Friends get your Flickr, Yelp, and Digg updates when they
e-mail you.
<http://www.microsoft.com/middleeast/windows/windowslive/see-it-in-action/so
cial-network-basics.aspx?ocid=PID23461::T:WLMTAGL:ON:WL:en-xm:SI_SB_3:092010
