[postgis-users] Filter 3D points with postgis, st_disjoint st_intersects
Bruno Friedmann bruno at ioda-net.ch
Tue Oct 13 23:16:53 PDT 2009
Hi all, I've just discover that I've a trouble (another) with 3D.
I've 2 set of records, one is full, the other have some hole inside.
I'm looking a way to extract ( building some 3d polygons or 3d lines ) point that are in the first full set, not present in the
second. ( Find the hole )
I was thinking about using st_intersects &| st_disjoint but I realize that
select st_disjoint(
st_setsrid(st_makepoint(585000, 226500, 0),21781),
st_setsrid(st_makepoint(585000, 226500, 100),21781)
st_intersects(
return false,true ... which should return true,false.
Did I need to invent my st_intersects3D function which would you st_intersects with X,Y and an another check on Z equality ?
Did you think it's a good idea.
PS : I'm using postgis 1.3.5 now, did the 1.4.0 release could help me in this case ?
Many thanks in advance for your precious advise
     Bruno Friedmann
