[postgis-users] make install problem in v. 1.4.0 as well as in 1.4.1.SVN
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Wed Oct 14 02:36:42 PDT 2009
Peter Sarkoci wrote:
> Hello everybody,
> trying to make a slackbuild script for Slackware 13.0 I encountered a problem.
> * Short description: "make install" does not copy the man pages into
> the destination directory. This applies to postgis 1.4.0 as well as to
> 1.4.1.SVN trunk.
> * Long description: I do the following (step by step):
> 1a) configure --prefix=/usr
> which runs without any problem, just complaining it is not able to
> find any XSL-template of the docbook system. Having on mind this could
> be the reason why, later on, make gives up to do anything with man
> pages I tried also
> 1b) configure --prefix=/usr
> --with-xsldir=/usr/share/xml/docbook/xsl-stylesheets-1.75.1
> in which case configure runs without complaints.
> 2) make
> 3) make install DESTDIR=/tmp/SBo/package-postgis
> runs also without complaints, but in the end, there are no man pages
> in the sub-directories of $(DESTDIR). Moreover, during both runs of
> "make" the directory with documentation is _never_ entered.
> * Now the question: is it my mistake, an intentional behavior or a
> bug? It is not a big problem anyway, within the slackbuild script I
> can fix the problem easily. On the other hand, it could turn out that
> such a fix is not the kosher way to go.
> Thanks
> Peter
Hi Peter,
The short version of this is that I think due to changes being made at
the time, it was felt that due to the large number of dependencies
required for the documentation then it should remain a separate target.
However, a manual "make install" in the docs/ directory should attempt
to put things in the right place for you - if it doesn't, then please
let us know.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
