[postgis-users] Where can I find the documentation to SQL shell (psql)?
Rick graham.rick at gmail.com
Wed Oct 14 13:04:58 PDT 2009
Henri
To get you started, this is what I do for a new install.  (to get you into psql)
First of all you need a user, the only initial user is 'postgres'
Also, you need to specify a database, the default is the database that
is the same name as the user.   There is one called 'postgres'
become the postgres user.
# su postgres  (or sudo su postgres)
# psql
Welcome to psql 8.3.8, the PostgreSQL interactive terminal.
Type:  \copyright for distribution terms
       \h for help with SQL commands
       \? for help with psql commands
       \g or terminate with semicolon to execute query
       \q to quit
postgres=# create role <you> with login superuser password <password>;
postgres=# ^D (or \q)
# ^D
you can now run psql as yourself, but you will want to create a
database to operate on...
# createdb <database>
# psql <database>
you're in.  you will have noticed that you get
enjoy, psql rocks for command line data manipulation and piping (as a filter)
On Wed, Oct 14, 2009 at 1:42 PM, Henri De Feraudy <feraudyh at yahoo.com> wrote:
> Hello,
>  I just installed PostgreSL on windows XP. Now if I click on the Start button and then on Programs and then PostgreSQL 8.4 one of the items is "SQL shell (psql)".
> I cant find the documentation to this. In the document called PostgreSQL 8.4.1 documentation there is no occurrence of the word "Shell".
> Henri
> postgis-users mailing list
Cheers!
Rick
