[postgis-users] 3dm point table def
Masanao Yajima yajiyajijp at yahoo.co.jp
Sat Oct 17 17:00:54 PDT 2009
Hi list
I have question regarding making 3DM point column in PostGIS.
When I try to insert POINTM(x,y,m),
if the dimension of the column is 3 it drops the M dimension,
and when I make the dimension 4 it asks for the z dimension.
How should I make the geometry column to have only x,y,m so I can insert
POINTM?
Here is example of the query
CREATE TABLE road(
  road_id INTEGER,
  road_name VARCHAR
SELECT AddGeometryColumn( 'road', 'roads_geom', -1, 'GEOMETRY',3 );
insert into temptest (road_id, road_name, roads_geom) values (21,'test',
ST_GeomFromEWKT('POINTM(191232 243118 1111)'))
select st_astext(roads_geom) from temptest
I appreciate your help!
Masanao Yajima
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091017/e5ced197/attachment.html>
