[postgis-users] Interoperability : SERIAL or Explicit Sequence
Ben Madin ben at remoteinformation.com.au
Fri Oct 23 13:34:46 PDT 2009
Fabrrice,
Check the PostgreSQL docs for this, but SERIAL is really just a
convenience word when declaring a table, not a type. Thye column type
will be integer.
If you subsequently pg_dump the table, it will dump the type as int
with the sequence creation commands in the script.
Finally, I believe that you would want (or need) to specify SERIAL
UNIQUE now to ensure primary key is unique.
Ben Madin
AusVet Animal Health Services
P.O. Box 5467
Broome   WA   6725
Australia
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
e : ben at ausvet.com.au
AusVet's website:  http://www.ausvet.com.au
This transmission is for the intended addressee only and is
confidential information. If you have received this transmission in
error, please delete it and notify the sender. The contents of this
email are the opinion of the writer only and are not endorsed by
AusVet Animal Health Services unless expressly stated otherwise.
Although AusVet uses virus scanning software we do not accept
liability for viruses or similar in any attachments.
On 23/10/2009, at 19:03, F T <oukile at gmail.com> wrote:
> Hello,
> I would like to design a Postgresql / Postgis database that would be
> the most interoperable as possible.
> The spatial tables could be used by (Select, Insert, Update, Delete) :
> - a Web GIS (Mapserver, geoserver, ...)
> - commercial clients (Geoconcept, Mapinfo, FME, ESRI)
> - Opensource clients (QGIS, GvSIG, ...).
> Great dream Isn't it? ...
> I know that some of these "soft" need to a numeric unique key
> (Mapserver for example don't deal with character keys...).
> I know OID are depreciated.
> I think is would be a good idea to add a unique numeric key to all
> my tables.
> What is the best way to do that?
>    - Add a SERIAL field (but it is PostgreSQL spécific?).
>    - Add a numeric field explicitely managed by an associated
> sequence (it does the same but seems more opened?).
> So SERIAL or EXPLICIT SEQUENCE?
> Thanks for your responses
> Fabrice
> postgis-users mailing list
