[postgis-users] Problem building PostGIS 1.4.0 on Ubuntu 9.04 (missing pgxs.mk)
antonio nuno de castro santa rosa santa rosa nunocsr at gmail.com
Fri Oct 30 12:01:24 PDT 2009
Gentlemen, my windwos is XP. My installation does not work. My test
time to perform the IMPORT command.
The Mateusz you have the recipe ....
thanks
Nuno
steps...
1- python-2.6.4.msi ;
2-numpy-1.3.0-win32-superpack-python2.6.exe ;
3-GDAL-1.6.1.win32-py2.6.exe;
4-gdalwin32exe160.
2009/10/30 Tyler Erickson <tyler.erickson at mtu.edu>:
> Installing the postgresql-server-dev-8.3 package added the missing pgxs.mk
> file and solved the issue.
> I thought I had correctly written the script to install
> postgresql-server-dev-8.3, but I seem to have outsmarted myself in using the
> environment variables.
> - Tyler
> Mateusz Loskot wrote:
>> Tyler,
>> I presume you have not installed postgresql-server-dev package for the
>> version of PostgreSQL you use.
>> Best regards,
>> Mateusz Loskot, http://mateusz.loskot.net
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Mateusz Loskot
> View this message in context: http://old.nabble.com/Problem-building-PostGIS-1.4.0-on-Ubuntu-9.04-%28missing-pgxs.mk%29-tp26131926p26133643.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
