[postgis-users] [postgis-devel] Geog/Geom Hack
Stephen Woodbridge woodbri at swoodbridge.com
Sat Oct 31 09:47:29 PDT 2009
Hi All,
For whatever its worth:
1) I really like the fact that we are addressing usability for the
masses. Just making it do the intuitive thing is good.
2) As someone that has invested a lot of time to learn the ins and outs,
I'm not sure I like the fact that all my functions may start behaving
differently as this thread seems to be implying. I like having control
over how my queries are evaluated and optimized.
3) Without knowing all the nuances of this thread, I would be in favor
of Nicklas' suggestion of add new function names for the hacks. Before
reading his response, I was thinking we could name all these functions
STT_... again the extra T for transform.
Its all goodness in my book, and I appreciate all the work everyone is
doing on this and look forward to a future release where I can try it out.
Best regards,
   -Steve W
Paragon Corporation wrote:
> Nicklas and Paul,
> Yap that's the main point.  To add
> I'm not really in disagreement with Paul.  I see his point too.  I'm
> just prodding him to think about all his use cases a little more because
> I don't feel he has.
> My feelings to sum up
> 1) We have not thought about the complete ramifications of this hack and
> I'm really concerned about the novice that transitions to an expert
> rather than just getting them hooked on PostGIS.  Perhaps I'm being
> overly silly with that and even said, Paul's approach might be an easier
> to transition solution.
> 2) My concern is the penalty of putting it in and having to take it out
> later might be very great (both from a code, testing,  as well as a
> mindset perspective).  I just feel it needs more thought and testing and
> really if we want to make our December deadline, I don't want it rushed
> in so lightly.
> Unless of course Paul -- you want to wait till January or February to
> release 1.5?
> Now the ST_Max_Distance is a separate issue.  I would put in the
> ST_ConvexHull hack in place.  The reason being is that it just improves
> performance any way I can think you slice it and an experienced user
> would do exactly the same thing always and when you finally incorporate
> it into the core function,  there is no change in existing code just a
> speed improvement.  So to me its basically our ST_DWithin hack -- a very
> tried and trued obvious answer.  Its an implementation detail with no
> clear leaky effects.
> With that said, there are some clear functions in geometry that are safe
> to put a geography cover over.  Those ones where there is clearly only
> one answer and don't involve transformation.
> like ST_X, ST_Y etc.  That don't require transformation so no screw up
> in data.  Also observe that even the geometry(geography .... in these
> there is no penalty becuase the geometry/geography isn't changing so the
> planner can cache the geometry to geography conversion.  The
> ST_Transformation ones however, the geometry/geography is changing
> slightly at each step since ST_Tranformation is a lossy operation so you
> are not only incurring overhead (because these answers can't be cached),
> but also adding in extra errors .
> To me this is a bleeding abstraction and that is the main reason I don't
> like it.
> So getting back to you Paul,
> What functions exactly are you planning to put a veil over?  ST_Buffer
> well that one is used so much and is not as exact anyway that I suppose
> I can grudgingly accept that as okay.
> Thanks,
> Regina
> *From:* postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] *On Behalf Of
> *nicklas.aven at jordogskog.no
> *Sent:* Saturday, October 31, 2009 10:04 AM
> *To:* PostGIS Development Discussion
> *Subject:* Re: [postgis-devel] Geog/Geom Hack
> Hallo
> I can see the points from both of you. I think the most important
> argument from you Regina is that it is not transparent enough. A
> skillfull user trying postgis might be disapointed when realizing that
> the nested functions caused an unnecessary big rounding-error.
> But if it is obvious that it is a "special" function at least for the
> experienced user knowing about common function-names I don't think it is
> a big problem and might work as an easy shortcut at least during the
> process of learning.
> As I understand it this could be a solution for using many functions
> against geography so, why not  note it in the function name like:
> ST_tBuffer for transformed buffer. Then when time is to introduse a
> "real" variant of the function they can coexist and it will not change
> the bahavior inside an application without someone consciously changes
> the function name and remove the t.
> the t would be independent of geography-geometry in semantics and just
> indicate that it is a lower-precision variant. I fit was commonly used
> it would work as a warning to experienced users.
> I have a similar question about st_max_distance. The function gets very
> much more effective when ran together with convexhull. I saw the trick
> in ST_MinimumBoundingCircle and id makes a big difference to do :
> st_max_distance(st_convexhull(the_geom)) instead of just
> st_max_distance(the_geom).
> The question is: Should that be put in the sql-function?
> My opinion now is that we just tell about it in the documentation and
> aims at doing that trick internally in C in the future. Maybe together
> with moving the whole convexhull to postgis-native from geos. It didn't
> look that impossible fromthe JTS-code.
> /Nicklas
> 2009-10-31 Paul Ramsey wrote:
> I still think I'm right :) Honestly, I've got to a lot of trouble to
>  >make this stuff for newbies, and I don't think "learn how it works" is
>  >the right answer for them. They had that option before, but taking GIS
>  >101 is not an option for these people, they need something that "just
>  >works". It's easier to teach the experienced people the pitfalls than
>  >the inexperienced people the basics.
>  >BTW, I just upgraded distance_sphere and distance_spheroid to be as
>  >powerful (handling point/line/polygon) as the geography variants,
>  >removing excuses for transforming geometries into geographies for
>  >processing purposes.
>  >P.
>  >On Fri, Oct 30, 2009 at 9:15 PM, Paragon Corporation wrote:
>  >> Paul,
>  >> For what its worth, here is another reason why I don't like this
> idea and I
>  >> think we should at least think about its ramifications more so
> should put it
>  >> off for consideration until 2.0.
>  >> In geometry processing, its common practice to apply a lot of
> functions in
>  >> succession
>  >> process1(process2(process3(geometry/geography)
>  >> With your hackish approach -- the unsuspecting novice user will be
> incurring
>  >> a lot of transformation rounding errors with each process
>  >> The advanced user, won't know if this is okay or not -- because they
> can't
>  >> tell by looking at the function call the hidden transformations
> going on.
>  >> If these did not exist, they would transform once before the
> processes and
>  >> once after) and incurr much less penalty
>  >> But if they both exist, they will treat them as being on equal footing
>  >> ST_Buffer(geometry)  and ST_Buffer(geography)
>  >> So your approach while well-meaning gives a questionable benefit to
> novices
>  >> and is putting experienced users at a disadvantage.
>  >> Thanks,
>  >> Regina
>  >> -----Original Message-----
>  >> From: postgis-devel-bounces at postgis.refractions.net
>  >> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
> Paragon
>  >> Corporation
>  >> Sent: Friday, October 30, 2009 11:54 PM
>  >> To: 'PostGIS Development Discussion'
>  >> Cc: 'PostGIS Users Discussion'
>  >> Subject: Re: [postgis-devel] Geog/Geom Hack
>  >> Paul,
>  >> I suppose we can't just put this decision off till 2.0.  Isn't this
> a bit of
>  >> scope creep?  I'm not absolutely sure which way is better, but I
> know the
>  >> cost of rolling back the change is more.
>  >> If you are going to do this, how many functions are you planning to
> do this
>  >> for?
>  >> I'm cc'ing the postgis users group too to get more of an opinion on this
>  >> topic.
>  >> So the question is it it a good idea to introduce a hack that
> transforms a
>  >> geography into what we call BestSRID to perform geometry operations
> on and
>  >> then transform back.  My concern is that this is a silent operation that
>  >> gives the impression that these functions are natively done in spheroid
>  >> space just for the benefit of  catering to less technical users.
> http://trac.osgeo.org/postgis/browser/trunk/postgis/geography.sql.in.c#L541
>  >> So you can't really tell by looking the penalty
>  >> Main examples of this as shown for ST_Buffer
>  >> CREATE OR REPLACE FUNCTION _ST_BestSRID(geography, geography)
>  >> 530         RETURNS integer
>  >> 531         AS 'MODULE_PATHNAME','geography_bestsrid'
>  >> 532         LANGUAGE 'C' IMMUTABLE STRICT;
>  >> 533
>  >> 534 -- Availability: 1.5.0
>  >> 535 CREATE OR REPLACE FUNCTION _ST_BestSRID(geography)
>  >> 536         RETURNS integer
>  >> 537         AS 'SELECT _ST_BestSRID($1,$1)'
>  >> 538         LANGUAGE 'SQL' IMMUTABLE STRICT;
>  >> 539
>  >> 540 -- Availability: 1.5.0
>  >> 541 CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8)
>  >> 542         RETURNS geography
>  >> 543         AS 'SELECT
>  >> geography(ST_Transform(ST_Buffer(ST_Transform(geometry($1),
>  >> _ST_BestSRID($1)), $2), 4326))'
>  >> 544         LANGUAGE 'SQL' IMMUTABLE STRICT;
>  >> 545
>  >> Thanks,
>  >> Regina
>  >> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
>  >> Ramsey
>  >> Sent: Friday, October 30, 2009 11:07 PM
>  >> To: PostGIS Development Discussion
>  >> We're going to have to agree to disagree on this one, Regina.
> Catering to
>  >> the less technical users is what this exercise is all about, to my
> mind, and
>  >> that includes allowing easy flipping into geometry for calculations that
>  >> aren't supported in geography yet. Oracle does this too.
>  >> What do other folks think?
>  >> P.
>  >> On Fri, Oct 30, 2009 at 7:06 PM, Paragon Corporation wrote:
>  >>> Paul,
>  >>> Hmm when I am comparing distance of two geometries in different
>  >>> spatial refs which I do a lot.
>  >>> I still don't like the hack even if you disregard the above or if you
>  >>> must hack -- don't give it the same name as the non-hacked functions.
>  >>> the whole idea of picking BestSRID for a person to cater to less
>  >>> technical users I find extremely annoying as I can think of 20
>  >>> "BestSRID" depending on what I am doing.  If they get to that level of
>  >>> sophistication, I would rather have them think a little more  and
>  >>> understand the implications of those decisions.
>  >>> We must learn to crawl before we can learn to walk,because walking
>  >>> without understanding will just get you into trouble in the long run.
>  >>>  Thanks,
>  >>> Regina
>  >>> Paul Ramsey
>  >>> Sent: Friday, October 30, 2009 9:47 PM
>  >>> You *can*, but I strongly doubt you *will*. Because there's nothing in
>  >>> geography that isn't already in geometry. So you as a primary geometry
>  >>> user are going to have no working need to cast things to geography.
>  >>> On the other hand, the very first question from users of geography
>  >>> will be "how can I access ?" So having a
>  >>> relatively full set of functions already available in geography makes
>  >>> sense to me, even if they are hacked in with a planar trick.
>  >>> P.
>  >>> On Fri, Oct 30, 2009 at 5:46 PM, Paragon Corporation wrote:
>  >>>> Paul,
>  >>>> I can put a functional geography index on can't I and take advantage
>  >>>> of geography index bindings?
>  >>>> Lets say I have a large network of tables broken out by region so I
>  >>>> know a specific table has one srid.
>  >>>> For many queries, I may go to that table directly or if I'm doing
>  >>>> single geometry processing, really don't care what srid as long as
>  >>>> its in utm or whatever - so I can use the full power of GEOS.
>  >>>> For my across the board distance checks and so forth, I would want to
>  >>>> use geography and I could use a geography index if I put a functional
>  >>>> geography index on my geometry correct?  Though that needs some more
>  >>> testing.
>  >>>> So in short if 90% of my workload involves geometry processing, I
>  >>>> will want to keep my data in geometry
>  >>>> But the 10% I would want to convert to geography on the fly.
>  >>>> Thanks,
>  >>>> Regina
>  >>>> Paul Ramsey
>  >>>> Sent: Friday, October 30, 2009 8:34 PM
>  >>>> I'm not sure I understand why you would ever convert a geometry to a
>  >>>> geography as part of a query on a geometry table. I fully expect
>  >>>> geography to be used as a storage type, because of the utility of
>  >>>> having the correct spherical indexes, which are not available when
>  >>>> you're just converting in via a cast. Since there's no functions
>  >>>> available on geography that are not already available on geometry,
>  >>>> why would you ever do a geometry->geography cast unless you are (a)
>  >>>> testing geography or (b) bulk converting a table into geography for
>  >>> storage in that type.
>  >>>> P.
>  >>>> On Fri, Oct 30, 2009 at 5:24 PM, Paragon Corporation wrote:
>  >>>>> Paul,
>  >>>>> I would rather you didn't for 2 reasons
>  >>>>> 1) I'm lazy and for each of these things we'd have to apply the text
>  >>>>> additional function proto hack to prevent from it breaking geometry.
>  >>>>> which we will probably end up taking out anyway.
>  >>>>> 2) I don't like the hiddenness of it since it becomes especially
>  >>>>> annoying if you have your native in geometry and you are converting
>  >>>>> to geography for a special usecase, then you end up with a slower
>  >>>>> implementation
>  >>>>> as you would really end up doing accidentally
>  >>>>> geometry -> geography -> geometry ->operation (and why do I want my
>  >>>>> calcs done in UTM?)
>  >>>>> Instead of the more efficient
>  >>>>> geometry -> operation
>  >>>>> Thanks,
>  >>>>> Regina
>  >>>>> Paul Ramsey
>  >>>>> Sent: Friday, October 30, 2009 8:16 PM
>  >>>>> Subject: [postgis-devel] Geog/Geom Hack
>  >>>>> I'm interested to know what the general opinion is of the trick I've
>  >>>>> used on
>  >>>>> ST_Buffer(geography):
>  >>>>> c
>  >>>>> #L541
>  >>>>> I ask because I could apply the same idea to the larger suite of OGC
>  >>>>> SFSQL predicates before release. Is half-a-loaf better than no loaf
>  >>>>> in
>  >>>> this case?
>  >>>>> (Note that there will be failure cases for really large geometry,
>  >>>>> like a polygon of "Asia" or "Russia" that have polygons over the
>  >>>>> dateline.)
>  >>>>> P.
>  >>>>> _______________________________________________
>  >>>>> postgis-devel mailing list
>  >>>>> postgis-devel at postgis.refractions.net
>  >>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> postgis-users mailing list
