[postgis-users] Make a shorter line from a given line
Daniel Grum daniel.grum at unibw.de
Wed Sep 9 12:40:17 PDT 2009
pcreso at pcreso.com schrieb:
> It sounds like you could use the linear referencing capability, along the lines of (untested, just off the top of my head)...
> select
> makeline(st_line_interpolate_point(geom,1-((st_length(geom)-100)/st_length(geom))),endpoint(geom))
> ie, make you new line the percentage along the original line required by your offset for the start point, and the endpoint remains the same.
> HTH,
>   Brent Wood
> --- On Thu, 9/10/09, Daniel Grum <daniel.grum at unibw.de> wrote:
>> From: Daniel Grum <daniel.grum at unibw.de>
>> Subject: Re: [postgis-users] Make a shorter line from a given line
>> To: nicklas.aven at jordogskog.no
>> Cc: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
>> Date: Thursday, September 10, 2009, 5:50 AM
>> schrieb:
>>> look at st_scale
>>> http://www.postgis.org/documentation/manual-1.4.1SVN/ST_Scale.html
>>>   or maybe st_transscale
>>> http://www.postgis.org/documentation/manual-1.4.1SVN/ST_TransScale.html
>>> /Nicklas
>>> 2009-09-08 Daniel Grum wrote:
>>> Hy,
>>>> I want to make a new line from a given line
>> -->both geometry types are
>>>> MULTININESTRING
>>>> Every step the new line should be "x meters"
>> shorter than the original.
>>>> I get the length of the line, f.e. 5000 meters
>> (length(the_geom)) and
>>>> after the step the new Line should be only 4000
>> meters.
>>>> I have a idea but it isn't ready:
>>>> UPDATE table
>>>> SET the_geom = (SELECT
>> MakeLine(StartPoint(line.the_geom),
>>>> EndPoint(line_merge(line.the_geom)))
>>>> FROM public.table line
>>>> ORDER BY line.gid);
>>>> But in if I do so I have no chance to say that the
>> new line has to be
>>>> 100meters shorter than the original line.
>>>> Are there any ideas how I can solve this problem?
>>>> Thanks,
>>>> --Daniel
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> That is not what I'm searching for.
>> Becaus the line lies somewhere in the 2D space and the end
>> point of the line anytime will be the same in my case...only
>> the starting point should be changed.
>> And it should be changed automaticly, step by step, and the
>> new starting point hvave to be on the old
>> line/route-->like a route in a map and every time step
>> the route will be shorter, because the unit has solved x
>> meters.
>> Do you know what I mean?
>> Scale and TransScale isn't the right finction I think.
>> --daniel
I changed the sql a bit:
UPDATE table
SET the_geom = (SELECT MakeLine(st_line_interpolate_point(line.the_geom,
(1-((Length(line.the_geom)-100)/Length(line.the_geom)))),
EndPoint(line.the_geom))
                            FROM public.table line);
But now the pgAdminIII says that the 1st argument of
st_line_interpolate() --> the_geom inst a line ...but the_geom is a line
and with length() I can can get the length of it...this is strange a bit.
--daniel
