[postgis-users] Import ESRI shapefiles into PostGIS
Cort D cdaniel at co.pierce.wa.us
Thu Sep 10 13:25:29 PDT 2009
Please can somebody tell me how to import my ESRI shapefiles and attribute
tables into PostGIS.
I have been trying to use the shp2pgsql function but its either i am not
using it correctly or its just not working for me.
Please can someone out there help me. I am very new to PostGIS application.
Cort wrote:
> Using shp2pgsql to import a shapefile to PostGIS is a two step process.
> First use shp2pgsql to create a *.sql file.  Then use psql to import the
> information in the *.sql file.   Read the PostGIS docs for specifics on
> the proper switches (
> http://postgis.refractions.net/docs/ch04.html#id2537503
> http://postgis.refractions.net/docs/ch04.html#id2537503 ).
View this message in context: http://www.nabble.com/Import-ESRI-shapefiles-into-PostGIS-tp25337392p25367851.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
