[postgis-users] PostGIS 1.4 install troubles
nicklas.aven at jordogskog.no nicklas.aven at jordogskog.no
Sat Sep 12 07:52:00 PDT 2009
The intersting part of the error message is the first error. It says that the postgis-1.4 is not found. Are you sure that you didn't get any error-message when you compiled postgis. I think you point to the wrong place for proj. I think it would be better to take away --with-projdir=/home/benton/proj-4.6.1 and see if it is found anyway.  But hopefully stackbuilder solves it :-) /Nicklas
2009-09-12 benton101 wrote:
>Hi Stephen,
>This is what the terminal produced ...
>benton at benton66:~$ sudo su - postgres
>$ psql -d template_test -f
>/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql
>BEGIN
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:53: NOTICE:
>type "spheroid" is not yet defined
>DETAIL: Creating a shell type definition.
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:53: ERROR:
>could not access file "$libdir/postgis-1.4": No such file or directory
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:59: ERROR:
>current transaction is aborted, commands ignored until end of transaction
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:65: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:71: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:78: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:88: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:94: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:100: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:106: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:112: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:118: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:124: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:130: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:136: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:142: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:153: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:164: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:170: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:177: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:183: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:190: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:196: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:203: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:209: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:216: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:222: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:229: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:235: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:241: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:247: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:253: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:259: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:266: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:272: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:279: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:285: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:293: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:300: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:307: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:313: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:323: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:329: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:335: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:341: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:348: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:356: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:361: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:368: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:374: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:379: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:384: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:391: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:397: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:403: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:409: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:415: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:421: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:427: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:433: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:439: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:445: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:451: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:457: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:467: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:473: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:479: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:485: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:493: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:503: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:509: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:515: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:521: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:528: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:536: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:542: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:548: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:554: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:560: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:566: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:572: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:578: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:584: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:590: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:596: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:602: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:608: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:614: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:620: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:626: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:632: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:638: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:651: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:657: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:663: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:669: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:675: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:681: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:687: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:693: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:699: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:705: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:711: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:717: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:727: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:733: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:739: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:745: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:750: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:760: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:771: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:777: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:783: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:789: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:795: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:801: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:807: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:813: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:819: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:825: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:831: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:837: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:843: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:849: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:855: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:861: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:867: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:873: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:879: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:885: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:891: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:897: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:903: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:909: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:915: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:921: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:927: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:933: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:941: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:947: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:953: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:959: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:965: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:971: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:977: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:983: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:989: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:995: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1001: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1007: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1014: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1019: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1024: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1029: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1034: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1039: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1044: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1074: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1084: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1090: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1096: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1102: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1108: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1114: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1120: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1126: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1136: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1142: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1148: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1154: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1160: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1166: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1172: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1178: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1184: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1190: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1196: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1202: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1208: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1214: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1220: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1230: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1236: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1242: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1248: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1254: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1260: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1266: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1272: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1284: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1290: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1296: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1302: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1307: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1313: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1321: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1327: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1333: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1339: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1345: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1351: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1359: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1365: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1371: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1377: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1383: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1389: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1397: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1404: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1410: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1416: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1422: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1428: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1434: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1440: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1447: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1453: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1460: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1466: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1472: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1478: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1484: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1490: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1500: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1506: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1512: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1518: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1525: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1531: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1537: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1543: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1549: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1555: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1561: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1567: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1573: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1579: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1586: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1592: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1598: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1604: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1610: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1616: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1622: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1628: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1634: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1640: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1646: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1652: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1658: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1664: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1670: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1676: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1682: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1688: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1694: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1700: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1706: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1712: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1718: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1724: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1730: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1736: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1742: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1748: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1754: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1760: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1766: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1772: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1778: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1784: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1790: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1796: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1806: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1812: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1818: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1824: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1830: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1836: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1842: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1848: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1854: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1860: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1866: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1872: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1878: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1884: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1890: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1896: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1902: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1908: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1914: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1920: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1926: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1932: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1938: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1944: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1950: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1956: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1962: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1969: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1975: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1981: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1987: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1993: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:1999: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2005: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2011: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2017: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2023: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2029: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2032: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2038: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2044: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2050: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2056: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2068: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2074: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2080: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2086: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2093: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2100: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2106: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2112: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2119: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2126: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2134: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2139: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2147: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2152: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2172: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2189: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2209: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2225: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2236: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2254: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2270: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2344: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2443: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2684: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2782: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:2992: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3010: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3028: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3099: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3121: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3143: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3188: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3200: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3213: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3301: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3317: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3333: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3373: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3386: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3393: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3398: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3404: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3413: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3417: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3427: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3431: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3436: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3440: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3444: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3448: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3452: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3498: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3508: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3514: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3520: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3526: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3532: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3538: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3544: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3550: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3556: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3562: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3568: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3574: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3580: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3586: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3593: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3599: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3605: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3611: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3617: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3623: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3629: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3635: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3641: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3647: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3653: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3659: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3665: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3668: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3669: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3670: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3671: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3672: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3673: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3674: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3675: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3676: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3677: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3678: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3679: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3680: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3683: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3684: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3685: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3695: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3701: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3708: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3714: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3721: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3727: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3734: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3740: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3747: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3753: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3759: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3765: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3775: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3781: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3787: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3793: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3799: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3805: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3811: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3817: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3823: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3829: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3839: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3845: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3851: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3857: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3863: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3869: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3875: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3881: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3888: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3894: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3902: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3910: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3918: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3924: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3930: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3936: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3942: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3948: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3954: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3960: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3966: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3972: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3982: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3988: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:3994: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4000: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4007: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4014: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4020: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4026: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4034: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4040: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4046: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4053: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4060: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4070: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4075: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4082: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4088: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4094: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4100: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4106: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4112: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4118: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4126: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4134: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4141: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4148: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4154: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4160: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4166: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4174: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4182: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4190: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4198: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4206: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4214: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4222: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4232: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4238: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4244: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4250: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4256: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4262: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4268: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4274: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4281: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4287: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4293: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4299: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4305: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4312: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4317: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4323: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4330: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4336: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4342: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4349: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4355: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4361: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4368: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4375: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4381: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4387: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4394: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4402: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4408: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4415: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4421: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4428: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4434: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4440: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4446: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4452: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4458: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4464: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4470: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4476: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4482: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4488: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4494: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4503: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4509: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4515: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4521: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4527: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4533: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4542: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4549: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4555: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4562: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4568: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4575: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4582: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4589: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4596: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4605: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4612: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4618: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4625: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4632: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4638: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4645: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4652: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4662: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4668: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4674: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4680: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4686: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4692: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4698: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4708: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4714: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4724: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4730: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4736: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4742: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4748: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4754: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4760: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4766: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4772: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4778: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4784: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4790: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4796: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4802: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4808: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4814: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4820: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4847: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4853: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4859: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4865: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4871: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4877: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4883: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4889: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4895: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4901: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4907: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4913: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4919: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4925: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4931: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4937: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4943: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4949: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4955: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4961: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4967: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4973: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4979: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4985: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4991: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:4997: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5003: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5009: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5015: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5021: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5027: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5033: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5039: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5044: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5050: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5055: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5061: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5071: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5081: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5091: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5102: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5112: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5122: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5132: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5142: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5148: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5154: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5164: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5174: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5184: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5194: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5200: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5206: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5212: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5218: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5229: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5240: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5250: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5260: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5266: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5272: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5278: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5284: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5294: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5304: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5314: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5324: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5330: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5336: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5342: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5348: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5354: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5364: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5374: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5384: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5394: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5400: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5406: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5412: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5418: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5429: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5440: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5451: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5462: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5468: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5474: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5480: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5486: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5496: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5506: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5516: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5526: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5536: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5546: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5556: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5566: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5576: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5586: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5596: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5606: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5616: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5626: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5636: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5646: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5656: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5666: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5676: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5686: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5696: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5706: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5716: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5726: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5736: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5746: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5756: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5766: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5776: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5786: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5796: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5806: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5816: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5826: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5836: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5846: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5856: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5866: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5876: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5886: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5896: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5906: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5916: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5926: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5937: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5948: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5959: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:5970: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6013: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6042: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6078: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6102: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6148: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6200: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6207: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6214: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6221: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6254: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6287: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6294: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6299: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6304: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6363: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6381: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6426: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6488: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6509: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6566: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6589: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6603: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6617: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6631: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6637: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6643: ERROR:
>current transaction is aborted, commands ignored until end of transaction
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6681: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6730: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6753: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6759: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6783: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6794: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6799: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6804: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6922: ERROR:
>block
>psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:6927: ERROR:
>block
>ROLLBACK
>$ ^C
>Thank You
>Ben
>View this message in context: http://www.nabble.com/PostGIS-1.4-install-troubles-tp25412943p25414868.html
>Sent from the PostGIS - User mailing list archive at Nabble.com.
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090912/32dc9ebf/attachment.html>
