[postgis-users] PostGIS upgrade 1.3 to 1.4
Ben Madin ben at remoteinformation.com.au
Sun Sep 13 17:54:58 PDT 2009
Thanks - certainly puts my mind at ease, although it was all
performing as expected.
cheers
Ben
On 14/09/2009, at 8:42 , Paragon Corporation wrote:
> Yap you can ignore all that.  Those are all expected messages.
> Hope that helps,
> Regina
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-
> users-bounces at postgis.refractions.net] On Behalf Of Ben Madin
> Sent: Sunday, September 13, 2009 6:21 PM
> To: PostGIS Users Discussion
> Subject: [postgis-users] PostGIS upgrade 1.3 to 1.4
> G'day all,
> since I'm following the manual, when I tried the soft upgrade, it
> seemed to work except for the following Notices:
> CREATE FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis_upgrade.sql:215:
> NOTICE:  type "box3d_extent" is not yet defined
> DETAIL:  Creating a shell type definition.
> CREATE FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis_upgrade.sql:219:
> NOTICE:  argument type box3d_extent is only a shell
> CREATE FUNCTION
> CREATE AGGREGATE
> psql:/usr/local/pgsql/share/contrib/postgis_upgrade.sql:2683:
> NOTICE:  type "pgis_abs" is not yet defined
> CREATE FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis_upgrade.sql:2687:
> NOTICE:  argument type pgis_abs is only a shell
> CREATE FUNCTION
> CREATE AGGREGATE
> psql:/usr/local/pgsql/share/contrib/postgis_upgrade.sql:2732:
> NOTICE:  aggregate accum_old(geometry) does not exist, skipping
> DROP AGGREGATE
> CREATE AGGREGATE
> psql:/usr/local/pgsql/share/contrib/postgis_upgrade.sql:2738:
> NOTICE:  aggregate st_accum_old(geometry) does not exist, skipping
> DROP AGGREGATE
> Not being overly knowledgable on PostGIS or PostgreSQL, do these
> matter? (I'd almost be confident to guess that the last two messages
> refer to the DROP AGGREGATE that follows the message?)
> cheers
> Ben
> Ben Madin
> REMOTE INFORMATION
> t : +61 8 9192 5455
> f : +61 8 9192 5535
> m : 0448 887 220
> Broome   WA   6725
> Out here, it pays to know...
> postgis-users mailing list
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090914/c4ae57f2/attachment.html>
