[postgis-users] PostgreSQL 8.3.8 and 8.4.1 out
Paragon Corporation lr at pcorp.us
Sun Sep 13 21:11:16 PDT 2009
It shouldn't be disturbed by the install as long as you don't do an initdb,
it should leave the data alone.
I guess you can shut down your postgresql daemon and copy the data to
another location.  Should probably do that anyway as a precautionary
measure.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of P Kishor
Sent: Sunday, September 13, 2009 9:14 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostgreSQL 8.3.8 and 8.4.1 out
On Sun, Sep 13, 2009 at 7:40 PM, Paragon Corporation <lr at pcorp.us> wrote:
> If you are running 8.3.5+
> Just replace the binaries for PostgreSQL (so if you compiled yourself,
> I guess that would be a recompile for you and install).   No change at
> all needed for the PostGIS part of it.
> For Linux -- if you are using the yum repository its just Yum upgrade
> For windows -- just download the PostgreSQL 8.3.8 and install ontop of
> your PostgreSQL 8.3.x (if you are running  8.3.5+) - again nothing to
> do for PostGIS
> Hope that helps,
Right. Actually, I am running the one OS not mentioned above... Mac OS X.
However, since I compiled everything meself, I guess I just recompile and
install PostGres. However, since my data lives at /usr/local/pgsql/data, I
am hoping that won't get disturbed by the Pg install, or will it?
> Regina
> Kishor
> Sent: Sunday, September 13, 2009 6:24 PM
> On Sun, Sep 13, 2009 at 12:31 AM, Paragon Corporation <lr at pcorp.us> wrote:
>> Just in case some people don't know.
>> PostgreSQL 8.3.8 and 8.4.1 came out last week and while they are
>> mostly security bug fixes, they do include some speed enhancements.
> I have PostGIS 1.4/PostGres 8.4. What is the recommended way of
> upgrading this combo? Do I have to recompile PostGres and then PostGIS
> again? Do I have to rebuild my databases? Is there a
> tutorial/knowledgebase article on the various upgrade paths possible?
>> For 8.4.1 -- "improve performance when processing toasted values in
>> index scans"
>> Which fixes the below bug.
>> http://postgis.refractions.net/pipermail/postgis-devel/2009-August/00
>> 6
>> 659.ht
>> ml
>> (though I guess it wasn't backported to 8.3 since I don't see it
>> listed in
>> 8.3.8 release notes)
>> http://www.postgresql.org/docs/8.4/static/release-8-4-1.html
>> For both 8.3.8, 8.4.1 -- has for "Fix Windows shared-memory allocation "
>> This bug led to the often-reported "could not reattach to shared memory"
>> http://www.postgresql.org/docs/8.3/static/release-8-3-8.html
>> Hope that helps,
>> Regina
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Puneet Kishor http://www.punkish.org
> Carbon Model http://carbonmodel.org
> Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
> Science Commons Fellow,
> http://sciencecommons.org/about/whoweare/kishor
> Nelson Institute, UW-Madison http://www.nelson.wisc.edu
> - Assertions are politics; backing up assertions with evidence is
> science
> = _______________________________________________
