[postgis-users] SRS Table Upgrade documentation
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Sep 14 02:50:06 PDT 2009
Ben Madin wrote:
> G'day all,
> having just (I think) upgraded PostGIS from 1.3.6 to  1.4.0 (still in
> PostgreSQL 8.3.7) I moved on in the documentation to :
> spatial_ref_sys table is restore from the dump, to ensure your custom
> additions are kept, but the distributed one might contain modification
> so you should backup your entries, drop the table and source the new
> one. If you did make additions we assume you know how to backup them
> before upgrading the table. Replace of it with the new one is done like
> this:
> $ psql newdb
> newdb=> drop spatial_ref_sys;
> DROP
> newdb=> \i spatial_ref_sys.sql
> but got the following message :
> australia=# \i /usr/local/pgsql/share/contrib/spatial_ref_sys.sql
> BEGIN
> psql:/usr/local/pgsql/share/contrib/spatial_ref_sys.sql:5: ERROR:
>  relation "spatial_ref_sys" does not exist
> Lines 1 to 5 of spatial_ref_sys.sql are :
> BEGIN;
> --- EPSG 3819 : HD1909
> INSERT INTO "spatial_ref_sys"
> ("srid","auth_name","auth_srid","srtext","proj4text") VALUES
> (3819,'EPSG',3819,'GEOGCS["HD1909",DATUM["Hungarian_Datum_1909",SPHEROID["Bessel
> 1841",6377397.155,299.1528128,AUTHORITY["EPSG","7004"]],TOWGS84[595.48,121.69,515.35,4.115,-2.9383,0.853,-3.408],AUTHORITY["EPSG","1024"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","3819"]]','+proj=longlat
> +ellps=bessel +towgs84=595.48,121.69,515.35,4.115,-2.9383,0.853,-3.408
> +no_defs ');
> so there is no table definition in the spatial_ref_sys.sql file.
> I would wonder if maybe truncate spatial_ref_sys; might be a better
> option...
> In the meantime, does anyone have the table definition for
> spatial_ref_sys.sql...?
> cheers
> Ben
Hmmm yeah. The definition for spatial_ref_sys can be found in
/usr/local/pgsql/share/contrib/postgis.sql (which is the file used for a
new installation), while the table content is in spatial_ref_sys.sql. So
the short answer is to copy/paste the spatial_ref_sys table definition
from postgis.sql into psql/pgAdmin and everything should work fine.
I'm not necessarily sure that this is a bug, however it doesn't seem to
be the most intuitive of behaviours...
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
