[postgis-users] Center of Points Collection
Paul Ramsey pramsey at cleverelephant.ca
Mon Sep 14 12:28:27 PDT 2009
Faster than creating a multipoint is to recognize that ST_Centroid()
is just going to return the center of the bbox of the collection
anyways, so you can replace it with.
SELECT ST_Centroid(ST_Extent(point_geom)) FROM pb_statistics WHERE pg_debit =1;
If you want to do it the hard way, then:
SELECT ST_Centroid(ST_Collect(point_geom)) FROM pb_statistics WHERE pg_debit =1;
P.
On Mon, Sep 14, 2009 at 12:24 PM, Dustin Butler <dustin at intrcomm.net> wrote:
> Hello,
> Trying to figure out how to find center using a collection of points.  For
> example something like this which doesn't work but you get the idea.
> SELECT ST_AsText(ST_Centriod(SELECT point_geom FROM pb.pb_statistics WHERE
> pb_debit=1));
> I think I need to make a multipoint geom out of the points and pass that but
> haven't figure out yet.
> Thanks,
> Dustin Butler
> Intrcomm Technology
> Skype: dustinbutler
> postgis-users mailing list
