[postgis-users] Postgresql crashing while using Postgis 1.4 on Postgresql 8.4
Paul Ramsey pramsey at cleverelephant.ca
Wed Sep 16 15:55:11 PDT 2009
My pg_restore doesn't seem to like that. Could you produce an ASCII
dump instead?
P
On Wed, Sep 16, 2009 at 3:37 PM, Emilie Laffray
<emilie.laffray at gmail.com> wrote:
> Paul Ramsey wrote:
>> Emilie,
>> We need to figure what function is taking down the server. First
>> remove the ST_IsValidReason from the query and see if it crashes. Then
>> try with only the ST_IsValidReason. Now you know which function is the
>> problem.
> The crash is happening on ST_IsValidReason.
>> Next, we need to know what data is causing the problem. Do a binary
>> search in your data (use a WHERE clause to restrict to just the first
>> half. Then the second half. Repeat the process on the half that causes
>> the crash. Keep going until you get to a minimum set of data that
>> causes a crash. now create a new table with just that data, dump it,
>> and send it to me.
> The behavior seems erratic. I thought I had it narrowed down to one
> line, but it wasn't the one line. However, I think I have found a subset
> that is making postgresql crash every time. There are only 23 entries.
> I hope it will be useful.
> Emilie Laffray
> Emilie  Laffray
> postgis-users mailing list
