[postgis-users] Postgresql crashing while using Postgis 1.4 on Postgresql 8.4
Paul Ramsey pramsey at cleverelephant.ca
Wed Sep 16 16:19:10 PDT 2009
It should come as no particular surprise that I can't reproduce the
problem with that table :) I took a *guess* and patched GEOS 3.1 svn
branch with what I think might be a fix. You can try that version of
GEOS or the GEOS svn trunk (which has a completely new implementation)
and see if the problems go away.
P
On Wed, Sep 16, 2009 at 3:59 PM, Emilie Laffray
<emilie.laffray at gmail.com> wrote:
> Paul Ramsey wrote:
>> My pg_restore doesn't seem to like that. Could you produce an ASCII
>> dump instead?
>> P
> Sure no problem. Please find a version of the file enclosed.
