[postgis-users] undefined symbol GEOSPreparedCovers on Ubuntu 9.04
Mike Leahy mgleahy at alumni.uwaterloo.ca
Fri Sep 18 10:38:52 PDT 2009
Hi Paul,
Thanks for the tip.  I had actually copied the source from another machine
that I had compiled on (with a newer geos), and 'make clean' didn't do its job
for some reason.  A fresh source solved it...thanks.
Mike
(sorry for the off-list reply Paul)
On September 18, 2009 12:58:37 Paul Ramsey wrote:
> At root, your postgis is compiled against a more recent version of
> GEOS than your system is finding. Track down that old geos and remove
> it.
> P
> On Fri, Sep 18, 2009 at 9:47 AM, Mike Leahy <mgleahy at alumni.uwaterloo.ca>
wrote:
> > Hello list,
> > I've just attempted installing PostGIS 1.4.0 on Ubuntu 9.04 (i386).
> > Everything seems to work okay up until I try loading PostGIS into a test
> > database:
> > postgres at mgleahy-dev:~$ psql -f
> > /usr/share/postgresql/8.3/contrib/postgis.sql test
> > BEGIN
> > psql:/usr/share/postgresql/8.3/contrib/postgis.sql:53: NOTICE:  type
> > "spheroid" is not yet defined
> > DETAIL:  Creating a shell type definition.
> > psql:/usr/share/postgresql/8.3/contrib/postgis.sql:53: ERROR:  could not
> > load library "/usr/lib/postgresql/8.3/lib/postgis-1.4.so":
> > /usr/lib/postgresql/8.3/lib/postgis-1.4.so: undefined symbol:
> > GEOSPreparedCovers
> > A quick search on the web didn't turn up anything that looked applicable.
> >  Has anyone got an idea what might be wrong?
> > Best regards,
> > Mike
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
