[postgis-users] Multipolygon
Maxime van Noppen maxime at altribe.org
Mon Sep 21 09:47:34 PDT 2009
On 09/21/09 18:50, eehab hamzeh wrote:
> Hello
> Is there are any command work like st_makeline to create a multipolygon.
> I have a table with a different record of polygon. I need to create
> multipolygon from them
> Any hint or directions
SELECT ST_Union(geom) FROM table;
This will perform the union of all the geometries in the geom column of
table. If you want to force the output type to Multipolygon :
SELECT ST_Multi(ST_Union(geom)) FROM table;
Maxime
