[postgis-users] problems with mapinfo file export to postgis
Karina Guardado kguardado at gmail.com
Fri Sep 25 15:19:01 PDT 2009
Hi all,
I have exported a Mapinfo file into postgres using the following statement:
ogr2ogr  -f  "PostgreSQL" -a_srs "EPSG:8913" PG:"host=localhost
user=mysusername dbname=mydatabase password=mypass"  mytabfile.TAB
but when I want to access by mapserver layer I just don't know how to make
que query for the geometry information because I found examples using
select the_geom from mytable
but this work fine with a shapefile  but with mapinfo have no idea about the
geometry part, so please if someone has an example or solution let me know
regards
karina
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090925/d38c60af/attachment.html>
