[postgis-users] Postgres/Postgis query very slow
Bruno Friedmann bruno at ioda-net.ch
Fri Apr 2 00:55:03 PDT 2010
On 04/01/2010 11:35 AM, iKey wrote:
> Hey,
> I've set up a Postgres database with Postgis support.
> Now I try to excecute the following query:
> SELECT DISTINCT p.*
> FROM punkte p, lines l
> WHERE l.tags LIKE '%"highway"="footway"%'
>     AND CONTAINS(BUFFER(l.the_geom, 500), p.the_geom)
> You can download the SQL's to create the tables from my server:
> http://thisisliving.info/sql.zip
> It should return all datasets from the table punkte that are within a buffer
> of 500m around the datasets of the lines table.
> Anyway the query works fine, but it's veeeeery slow. It takes about 10
> minutes to get the results (1969).
> Now my question is if there is a way to speed up the query a bit.
> All help is appreciated.
> Thank you
> Eike Lüders
Hi I've made some test with your data
Original select 1969 rows in 765196ms
select line toke 50ms to test the like operator
The optimized query as proposed ....
select distinct p.* from punkte p,lines l WHERE l.tags LIKE '%"highway"="footway"%'
and st_dwithin(l.the_geom,p.the_geom,500)
order by p.gid
select optimized 1969 rows 989 ms
Sure there's a significant difference....
What I've made is adding also a gist index on each table like
CREATE INDEX lines_gist
  ON lines
  USING gist
  (the_geom);
with the index the first non-optimized query is working a bit slowly 777185ms.
     Bruno Friedmann
