[postgis-users] is there any 'common' geometry type?
Stephen Woodbridge woodbri at swoodbridge.com
Mon Apr 12 20:40:34 PDT 2010
Li Li wrote:
> I have a table from oracle. a spatial column geom  is SDO_GEOMETRY. I
> migrated it to postgis. this geom column has record with type of
> POLYGON and MULTIPOLYGON. is there any common type that can store any
> geometry?
The common type in PostGIS is "geometry", but you can also change the
constraints you table to allow both POLYGON and MULTIPOLYGON.
Or you can do something like:
update mytable set the_geom = ST_Multi(the_geom)
  where ST_GeometryType = "POLYGON';
-Steve W
