[postgis-users] st_area and 0.001953125 (Possible Bug)
Birgit Laggner birgit.laggner at vti.bund.de
Thu Apr 15 07:16:30 PDT 2010
Hi Marc,
I only wanted to remark that not only small polygons are affected by
this phenomenon - all areas I calculated with st_area() are multiples of
0.001953125 (what's not as it should be as appears to me).
I would have commented this at the link you attached, but I don't know
how (do I have to login or anything else?).
Regards,
Birgit.
On 15.04.2010 15:51, Marc Jansen wrote:
> Hi Birgit,
> good catch. I am pretty sure this is some sort of a bug, possibly
> related to 32-/64-bit architecture.
> I opened a bug [1], and cced Birgit. Add comments there as you dig
> deeper.
> Regards,
> Marc
> [1] http://trac.osgeo.org/postgis/ticket/503
> Birgit Laggner wrote:
>> Hi Maxime,
>> well, this would argue against the guess from Marc regarding the
>> versions change from 1.4.0 to 1.4.1 (I can't imagine that 1.5.1 has
>> errors that were already debugged in 1.4.1). What catches my eye is that
>> all systems that show the error are 64-bit systems and the one from Marc
>> providing the true result is a 32-bit system. Maybe this could be
>> leading to an explanation??
>> Thanks  and regards,
>> Birgit.
>> On 15.04.2010 13:48, Maxime van Noppen wrote:
>>> On 04/15/2010 01:37 PM, Marc Jansen wrote:
>>>> Hi Birgit,
>>>> I can confirm your results on
>>> To help tracking down the bug: I have the same problem (areas
>>> 0.001953125 or 0 for the query on the pastebin) on :
>>> PostgreSQL 8.4.3 on x86_64-unknown-linux-gnu, compiled by GCC gcc (GCC)
>>> 4.4.3 20100316 (prerelease), 64-bit
>>> POSTGIS="1.5.1" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September
>>> 2009" LIBXML="2.7.6" USE_STATS
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
