[postgis-users] ST_MakePolygon to represent a square
Paragon Corporation lr at pcorp.us
Sun Apr 18 13:23:22 PDT 2010
Aurélien,
Probably easier to use ST_MakeEnvelope to make a 4 sided polygon.  Also
remember x is long and y is lat
http://www.postgis.org/documentation/manual-1.5/ST_MakeEnvelope.html
INSERT INTO geo_countries (id, box)
    SELECT id, geography(ST_MakeEnvelope(min_longi, min_lati, max_longi,
max_lati,4326))
 FROM countries;
Leo and Regina,
http://www.postgis.us
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Aurélien
Sent: Saturday, April 17, 2010 7:53 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] ST_MakePolygon to represent a square
Hello everybody,
I'm new on Postgis and I need help to create / fill a table.
I have to make a column which represent a square (min_lati, min_longi,
max_lati, max_longi). I've done this :
CREATE TABLE geo_countries (
        id bigint PRIMARY KEY,
        box geography(POLYGON,4326));
    SELECT id, ST_MakePolygon(??) FROM countries;
Is the POLYGON type is correct to make this ?
The "countries" table have the fields min/max lati/longi, but I don't know
how to make a polygon with SQL command...
Can you help me ?
Thank you very much,
Aurélien
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100418/7c88f507/attachment.html>
